What is this rubber seal in rear hub Timken kit? https://www.ausmini.com/forums/viewtopic.php?f=2&t=88203 |
Author: | Morbo28 [ Sun Jan 04, 2015 7:18 pm ] |
Post subject: | What is this rubber seal in rear hub Timken kit? |
Hi all, I'm reconditioning the rear hubs and there's an item in the Timken roller bearing that I am not sure about. See below pic - there are the two roller bearings and races, the dust seal, a split pin. But there is also a slim round rubber seal. I'm not sure how it fits in the hub. Any directions would be greatly appreciated please! ![]() |
Author: | drmini in aust [ Sun Jan 04, 2015 7:50 pm ] |
Post subject: | Re: What is this rubber seal in rear hub Timken kit? |
It's an O-ring, I believe it goes onto the shaft first, before the bearings do. |
Author: | Morbo28 [ Sun Jan 04, 2015 8:02 pm ] |
drmini in aust wrote: It's an O-ring, I believe it goes onto the shaft first, before the bearings do. Thanks for the reply. Sorry, I'm not sure I catch your drift. I have installed the bearing races and bearings into the hub assembly. Then this complete hub needs to be mounted onto the stub axle. So the bearings don't really go onto a shaft as such when they are first installed. Do you mean I need to put the o-ring onto the stub axle before I mount the hub and torque it up with the castle nut? I'm sure you're right, I'm just checking to make sure I understand it correctly. |
Author: | Scoop [ Sun Jan 04, 2015 9:21 pm ] |
Thats how I read the Docs responce. O ring on the stub first, then hub assembly. |
Author: | Morbo28 [ Sun Jan 04, 2015 9:24 pm ] |
Scoop wrote: Thats how I read the Docs responce. O ring on the stub first, then hub assembly. Cool, thanks both of you! |
Author: | drmini in aust [ Sun Jan 04, 2015 9:37 pm ] |
Yes that ^^^ is correct. Hint: If the roller bearings bind a bit when torqued up, back the nut off to the next pin hole. Otherwise you will `brinell' the bearings. The rear bearing setup is similar to the front wheel hub on say a Holden, there is no operational reason why it has to be `torqued up' like Mini front hubs do, [edit] when tapered roller bearings are fitted]. There is no drive torque transmitted through it. |
Author: | Morbo28 [ Sun Jan 04, 2015 10:06 pm ] |
Thanks Doc for confirming that. And also for confirming what I'd read; that these don't need the old torque like the original ones, so I'll tighten these like other cars I've had as you described. This forum is a great resource for me doing my rebuild. |
