It is currently Sat Jul 19, 2025 7:29 pm
 Post subject: Clutch slave travel
PostPosted: Sat Feb 21, 2015 10:45 pm
Hi all,
Just wondering if anyone with a tiptop pre-verto clutch system could do me a solid and measure the total travel in the slave cylinder when the clutch pedal is pushed (so, how far the end of the pushrod moves)?
Thanks!
 Post subject: Re: Clutch slave travel
PostPosted: Sun Feb 22, 2015 2:12 pm
The full throw of a new/good clutch slave cylinder pushrod is 19-21mm (on '69-'70 clutch). Check that when you are measuring that travel, there is a clearance between the head of the adjustment stop screw and the clutch lever.
Hope that's clear...
Bill
PostPosted: Sun Feb 22, 2015 7:22 pm
Thanks for that Bill :-)
PostPosted: Mon Feb 23, 2015 7:28 am
We used to, and I still do, throw the slave cylinder return spring away. It then makes clutch 'self adjusting', been doing that for about 40 years, never had a problem.
PostPosted: Wed Feb 25, 2015 8:46 pm
Sorry to hijack the original question although it seems to have been answered. So, without the return spring, what effect does that have on the feel of the clutch pedal? I broke a spring once and the pedal felt very soft. Should that be the effect?
Bill
PostPosted: Wed Feb 25, 2015 8:50 pm
IMHO...no.
Having got rid of the spring I can't say I've noticed a difference..
Cheers, Ian
PostPosted: Wed Feb 25, 2015 9:30 pm
Without the spring the release bearing will contact or spin with flywheel all the time.
Other than that it shouldnt feel any different
....you just lost him his insurance bonus!
997
PostPosted: Wed Feb 25, 2015 10:45 pm
Bleed first.
It's easy once you know how.
