Front subframe movement https://www.ausmini.com/forums/viewtopic.php?f=2&t=88226 |
Author: | Harley [ Tue Jan 06, 2015 9:55 pm ] |
Post subject: | Front subframe movement |
I've noticed lately that I can feel the subframe moving under my feet when I drive my car. I checked the bolts the other day and all were tight, except for the two under the pedals so I retightened them - however I can still feel the floor flexing a small amount when driving around (when not wearing shoes). Last time I checked the floor and frame were solid in that area, though it's been a while so I'll clamber under for a look on the weekend. Is the normal? If not, could it be related to the dual engine stabilisers I have connecting the sump to the bottom of the subframe? (car is a 68 model, with dry front subframes) Thanks. ![]() |
Author: | peterb [ Wed Jan 07, 2015 7:36 am ] |
Post subject: | Re: Front subframe movement |
Do you have the ones that bolt to sub frame bolts? If so that might be it, there's a fair bit of torque leverage through them, I prefer the double top mounts. |
Author: | Harley [ Wed Jan 07, 2015 8:19 am ] |
No, my lower stabilisers had to have two extra holes drilled in the frame, about 4-6 inches infront of the floor mounts. |
Author: | Morris 1100 [ Wed Jan 07, 2015 9:27 am ] |
The floor possibly needs stiffening because of the extra loads that are getting fed in that area. BMC Australia stiffened the 1100 floor across the frame mounts. |
Author: | 9YaTaH [ Wed Jan 07, 2015 9:29 am ] |
Floor may be cracked? Steering Rack may be moving? |
Author: | Mick [ Wed Jan 07, 2015 9:30 am ] |
Do the mini racers stiffen their floors? |
Author: | Harley [ Wed Jan 07, 2015 9:39 am ] |
Ill look into strengthening and for cracks- but wouldnt have thought a standard 50hp engine would be enough to do anything......but with a 47 year old car its a lot of work over time in that area. Ill check the rack too thats a good idea, but theres no movement in the kickpanel so im hoping thats fine. |
Author: | wild_willy [ Wed Jan 07, 2015 11:45 am ] |
If the 6 nuts and bolts are tight and the 4 tower top studs or bolts are tight then its time to look for cracks. Most common is the welds on the tower tops. |
Author: | Harley [ Mon Jan 12, 2015 12:10 pm ] |
Well I finally pulled up the carpets and climbed under the car for a look - no cracks in the subframe or body regions, which is good. I then checked all the nuts for tightness and though not movable by hand, with a spanner on them the tower studs moved more than I'd have liked - so all tightened up now to something far more solid. I also replaced the washers on the floor mounting bolts with bigger ones as the ones I took out have deformed in shape a bit. Took the car for a drive and no movement now - all fixed. ![]() |
Author: | drmini in aust [ Mon Jan 12, 2015 12:54 pm ] |
Years ago when I tracked mine I found the 4 floor bolts used to work loose. So I fitted locknuts, problem solved. You could use nyloc nuts instead. |
Author: | mickmini [ Mon Jan 12, 2015 5:56 pm ] |
Mick wrote: Do the mini racers stiffen their floors? Some do. ![]() |
