It is currently Sun Aug 17, 2025 2:30 pm
PostPosted: Sun Jan 11, 2015 1:24 pm
Im at work and need help.... does anyone know the size of the two threaded bolts on the front subframe that bolt up into the boxed firewall area, and the sized of the thread of the rear suspension springs that go through the wheel arch into the boot?
I need to make a trip to the hardware for a new painting frame, but dont have the details on me
Thanks
PostPosted: Sun Jan 11, 2015 1:27 pm
Front subframe tower bolts are 5/16" UNF.
Rear helper spring threads are also 5/16" UNF, with Nyloc nuts.
PostPosted: Sun Jan 11, 2015 1:33 pm
Fantastic
thanks for the quick reply.... Let the frame building commence!!
PostPosted: Sun Jan 11, 2015 4:13 pm
The subframe tower studs are stepped - they take 5/16 unf nuts at the top, but the threads in the subframe itself are 3/8 unf.
PostPosted: Sun Jan 11, 2015 5:38 pm
But if they are bolts like mine (hydro, as he has rear helper springs) not studs, the tower threads are 5/16" UNF.
Users browsing this forum: No registered users and 336 guests
