It is currently Sat Aug 16, 2025 9:27 pm
 Post subject: su needle size
PostPosted: Sun Jan 11, 2015 4:50 pm
Hi, what size needle should I be using with a 1.5inch single su on a fairly standard 998?
thanks
 Post subject: Re: su needle size
PostPosted: Sun Jan 11, 2015 5:35 pm
Well it's got a .090" main jet. It should run one of the .090" family of needles.
I put a CP4 needle in a 998 recently that had an HS4 (1-1/2") carby with a sports filter on, it's running fine.
[edit] this is a fixed needle. I don't like swinging needles, they wear the jet out.
Last edited by drmini in aust on Sun Jan 11, 2015 8:07 pm, edited 1 time in total.
PostPosted: Sun Jan 11, 2015 7:49 pm
MiniSpares Stage 1 kit for 998 uses NEEDLE AAU SWINGING, STAGE ONE USE. I had one of these on my 998 and it worked just fine :)
PostPosted: Sun Jan 11, 2015 8:41 pm
I'm using the same AAU with a complete minispares stage one kit on my 998
PostPosted: Mon Jan 12, 2015 12:24 pm
I used the needle that came with my stage 1 kit, but it was miles off. It needed a lot of filing to get it good - it was fine at idle and high revs, but leaned out on the mid-range. Mine was a standard 998 with a 1.5" carb.
Users browsing this forum: No registered users and 303 guests
