su needle size
https://www.ausmini.com/forums/viewtopic.php?f=2&t=88260
Author:  nicholasatkins [ Sun Jan 11, 2015 4:50 pm ]
Post subject:  su needle size
Hi, what size needle should I be using with a 1.5inch single su on a fairly standard 998?
thanks
Author:  drmini in aust [ Sun Jan 11, 2015 5:35 pm ]
Post subject:  Re: su needle size
Well it's got a .090" main jet. It should run one of the .090" family of needles.
I put a CP4 needle in a 998 recently that had an HS4 (1-1/2") carby with a sports filter on, it's running fine.
[edit] this is a fixed needle. I don't like swinging needles, they wear the jet out.
Author:  leonrjohnson [ Sun Jan 11, 2015 7:49 pm ]
MiniSpares Stage 1 kit for 998 uses NEEDLE AAU SWINGING, STAGE ONE USE. I had one of these on my 998 and it worked just fine :)
Author:  timmy201 [ Sun Jan 11, 2015 8:41 pm ]
I'm using the same AAU with a complete minispares stage one kit on my 998
Author:  Irish Yobbo [ Mon Jan 12, 2015 12:24 pm ]
I used the needle that came with my stage 1 kit, but it was miles off. It needed a lot of filing to get it good - it was fine at idle and high revs, but leaned out on the mid-range. Mine was a standard 998 with a 1.5" carb.
