It is currently Mon Aug 11, 2025 12:00 pm
PostPosted: Tue Jan 13, 2015 11:01 am
Hi all
There is an 1100S engine I am interested in buying. I can only get limited info from the owner at present inc engine number. I am assuming the later thick flange block is slightly better? Does anyone know around what engine number they swapped to a thick flange?
James
PostPosted: Tue Jan 13, 2015 11:16 am
I have had to build both thin and thick flange 1100S, IMO both are as good as each other.
These blocks are both much stiffer than a Cooper S block so the same criticisms don't apply.
[edit] at 12YD/Ta/H7611 they were still thin flanged.
12YD/Ta/H8667 is a thick one. So somewhere in between 7611 and 8667.... they changed.
PostPosted: Tue Jan 13, 2015 11:48 am
Thanks Doc - typical - the one I'm interested in is right in the middle of those numbers.. 79xx.
I read somewhere that they changed from a small to large journal crank too? Would that make much difference either?
PostPosted: Tue Jan 13, 2015 12:18 pm
the change from small journal to large journal didn`t happen at the same time as thin flange to thick flange tho
PostPosted: Tue Jan 13, 2015 12:21 pm
They changed from small journal to large around 12YD/Ta/H10500. I'll dig out the actual number shortly.
[edit] it was at 10487/10488.
Personally I prefer the small journal. Large journal cranks have poorer counterweighting and their rods are lots heavier.
PostPosted: Tue Jan 13, 2015 12:54 pm
Thanks Doc :)
