68 Deluxe https://www.ausmini.com/forums/viewtopic.php?f=2&t=88396 |
Page 1 of 2 |
Author: | sako [ Thu Jan 22, 2015 5:57 pm ] |
Post subject: | 68 Deluxe |
Hi all, Just after some input on this 68 Deluxe. http://www.gumtree.com.au/s-ad/melbourn ... 1067518736 It is listed as an 1100 however after speaking to the owner he thinks it is a 998, is anyone able to identify from the photos? Apparently also has a disc front end, would this be standard for this year model or or after market? Would the specs be the same as a Cooper S front end? Any other input on this vehicle would be appreciated as I will inspecting it shortly. Thanks, |
Author: | 1018cc [ Thu Jan 22, 2015 6:04 pm ] |
Post subject: | Re: 68 Deluxe |
The 998 and 1100 are visually the same from the outside. As it mentioned a fresh rebuild it could be either (only the cranks and pistons are different between the two engines). De Luxe should've had drums standard. Could be 7.5" Cooper S discs on the front, 7" Cooper, 8.4" or some custom concoction of Camira discs and custom bracketry etc |
Author: | gtogreen1969 [ Thu Jan 22, 2015 6:09 pm ] |
Its registered with an 1100 Victorian Registration Number DDH148 VIN/Chassis Number 35088 Engine Number 10YCTAH7657 Colour GREEN Make MORRIS Body Type COUPE Compliance Plate Date 190000 Year Of Manufacture 1968 |
Author: | sako [ Thu Jan 22, 2015 6:14 pm ] |
Thanks for the info. Is there any easy easy to visually identify what the discs may be from? |
Author: | Mick [ Thu Jan 22, 2015 6:23 pm ] |
Pretty uncommon to get a set of 997 7" discs, so it will more likely be 7.5 or 8.4" varieties if not a Camira custom job which is also reasonably unlikely. With the exception of the 7" discs, all are very good. You will need to ask the question as their is not an image to give the brake setup away. |
Author: | sako [ Thu Jan 22, 2015 6:30 pm ] |
Thanks Mick, I asked the owner and he was under the impression that they came like that from the factory. I'll see how I go. |
Author: | Mick [ Thu Jan 22, 2015 6:40 pm ] |
They may be factory brakes, from another mini model, but the deluxe came with drums alone. Discs are always welcome however on any model. |
Author: | boomini [ Thu Jan 22, 2015 10:21 pm ] |
Nice looking mini.... It appears to be on 12"rims so my guess would be 8.4" discs. As mick said any discs on a mini are an upgrade. |
Author: | peterb [ Fri Jan 23, 2015 6:47 am ] |
sako wrote: Thanks Mick, I asked the owner and he was under the impression that they came like that from the factory. I'll see how I go. Maybe its a Cooper S that someones rebadged to look like a Mini Deluxe. ![]() |
Author: | sako [ Fri Jan 23, 2015 6:08 pm ] |
I can only hope so |
Author: | sako [ Wed Jan 28, 2015 6:41 pm ] |
Rims are 12 inch, not sure what the brakes might be? ![]() |
Author: | Scoop [ Wed Jan 28, 2015 7:46 pm ] |
Mini discs. Possibly 8.4's |
Author: | sako [ Wed Jan 28, 2015 7:48 pm ] |
Thanks scoop, I was hoping for 7.5's |
Author: | Scoop [ Wed Jan 28, 2015 7:56 pm ] |
You would have been able to tell by taking a wheel off and looking at the drive flange. I'm basing my view on the lack of clearance between the caliper and the rim. Would think there would be a little more if 7.5s |
Author: | tasti [ Wed Jan 28, 2015 8:48 pm ] |
If the wheels are 10inch I really doubt that they will be 8.4s as you need 12inch wheels to fit 8.4s. My guess is that you have 7.5s |
