Gearbox Third motion bearing retainer. https://www.ausmini.com/forums/viewtopic.php?f=2&t=88417 |
Author: | mini0998 [ Sat Jan 24, 2015 1:19 pm ] |
Post subject: | Gearbox Third motion bearing retainer. |
I am currently in the middle of my gearbox rebuild and everything has gone together fine so far however I have checked the gap between the 3rd motion bearing retainer and the gearbox and without any shims the gap with feeler gauge is only about 2 thou of an inch. In some places around the retainer I can't even get the 2 thou feeler gauge in. Would this be an acceptable amount of clearance to retain the 3rd motion bearing once the retainer is tightened? |
Author: | drmini in aust [ Sat Jan 24, 2015 1:51 pm ] |
Post subject: | Re: Gearbox Third motion bearing retainer. |
Yes. It will be fine. Contrary to the belief of some, putting more shims gives less preload against the bearing's circlip. Because you are shimming the retainer out. |
Author: | mini0998 [ Sat Jan 24, 2015 2:01 pm ] |
Thanks Doc |
