It is currently Sat Jul 19, 2025 4:25 pm
PostPosted: Mon Jan 26, 2015 6:42 pm
I've been cleaning up the wiper arms of the deluxe I am restoring and the need some advice on fixing an issue. The stainless pin that holds the arm onto the wiper arm mount is missing a side. The other arm is missing the pin all together. I tried minisport and minispares for the parts but no luck. Can you buy these pins or am I up for new arms?
67 Deluxe under going full resto
PostPosted: Mon Jan 26, 2015 6:47 pm
Online
Just fit new arms, the holes will be worn in those ones.
I bought Tek S/S ones from Minispares UK.
If it's an Oz built Mini from 1968 on though, you will have to bend the end on the Teks where the blades fit onto.
Local bought arms should fit OK. [for example] Kc has S/S ones for $14 approx.
PostPosted: Mon Jan 26, 2015 7:03 pm
Knackered then. Cheers Doc.
Users browsing this forum: drmini in aust, watsupskip and 75 guests
