It is currently Sun Jul 20, 2025 10:24 am
 Post subject: 68 Deluxe
PostPosted: Thu Jan 22, 2015 5:57 pm
Hi all,
Just after some input on this 68 Deluxe.
http://www.gumtree.com.au/s-ad/melbourn ... 1067518736
It is listed as an 1100 however after speaking to the owner he thinks it is a 998, is anyone able to identify from the photos?
Apparently also has a disc front end, would this be standard for this year model or or after market? Would the specs be the same as a Cooper S front end?
Any other input on this vehicle would be appreciated as I will inspecting it shortly.
Thanks,
 Post subject: Re: 68 Deluxe
PostPosted: Thu Jan 22, 2015 6:04 pm
Give Ash some flowers Nick .
The 998 and 1100 are visually the same from the outside. As it mentioned a fresh rebuild it could be either (only the cranks and pistons are different between the two engines).
De Luxe should've had drums standard. Could be 7.5" Cooper S discs on the front, 7" Cooper, 8.4" or some custom concoction of Camira discs and custom bracketry etc
PostPosted: Thu Jan 22, 2015 6:09 pm
Its registered with an 1100
Victorian Registration Number DDH148
VIN/Chassis Number 35088
Engine Number 10YCTAH7657
Colour GREEN
Make MORRIS
Body Type COUPE
Compliance Plate Date 190000
Year Of Manufacture 1968
PostPosted: Thu Jan 22, 2015 6:14 pm
Thanks for the info.
Is there any easy easy to visually identify what the discs may be from?
PostPosted: Thu Jan 22, 2015 6:23 pm
Pretty uncommon to get a set of 997 7" discs, so it will more likely be 7.5 or 8.4" varieties if not a Camira custom job which is also reasonably unlikely.
With the exception of the 7" discs, all are very good. You will need to ask the question as their is not an image to give the brake setup away.
PostPosted: Thu Jan 22, 2015 6:30 pm
Thanks Mick,
I asked the owner and he was under the impression that they came like that from the factory.
I'll see how I go.
PostPosted: Thu Jan 22, 2015 6:40 pm
They may be factory brakes, from another mini model, but the deluxe came with drums alone.
Discs are always welcome however on any model.
PostPosted: Thu Jan 22, 2015 10:21 pm
Nice looking mini....
It appears to be on 12"rims so my guess would be 8.4" discs.
As mick said any discs on a mini are an upgrade.
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Fri Jan 23, 2015 6:47 am
sako wrote:
Thanks Mick,
I'll see how I go.
Maybe its a Cooper S that someones rebadged to look like a Mini Deluxe. :wink:
PostPosted: Fri Jan 23, 2015 6:08 pm
I can only hope so
PostPosted: Wed Jan 28, 2015 6:41 pm
Rims are 12 inch, not sure what the brakes might be?
PostPosted: Wed Jan 28, 2015 7:46 pm
Online
Mini discs. Possibly 8.4's
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Wed Jan 28, 2015 7:48 pm
Thanks scoop, I was hoping for 7.5's
PostPosted: Wed Jan 28, 2015 7:56 pm
Online
You would have been able to tell by taking a wheel off and looking at the drive flange. I'm basing my view on the lack of clearance between the caliper and the rim. Would think there would be a little more if 7.5s
5/72 Clubman Gt
PostPosted: Wed Jan 28, 2015 8:48 pm
If the wheels are 10inch I really doubt that they will be 8.4s as you need 12inch wheels to fit 8.4s. My guess is that you have 7.5s
Users browsing this forum: Scoop and 80 guests
