A panel measurement needed
https://www.ausmini.com/forums/viewtopic.php?f=2&t=88446
Author:  doogie [ Mon Jan 26, 2015 10:12 pm ]
Post subject:  A panel measurement needed
Anybody with a 71-73 clubman, I need the measurements for the holes for the A panel badges, I need to redrill the holes as I replaced both panels.
Doogie
Author:  simo74 [ Tue Jan 27, 2015 7:18 am ]
Post subject:  Re: A panel measurement needed
I assume you mean the little square leyland badge on the bottom of the A panel, as in this picture. I am at work at the moment but can have a go at measuring tonight if no one else can do it sooner.
Author:  doogie [ Tue Jan 27, 2015 8:54 am ]
That's the badge, thank you.
Doogie
Author:  1310/71 [ Tue Jan 27, 2015 9:12 am ]
Doing a concourse restoration Doogie?
Were they ever that precise in the factory?
Author:  Goldbrocade_62 [ Tue Jan 27, 2015 9:55 am ]
On one of my cars with the bottom hinge in place, from the top of hinge to centre of first hole is 36mm and from door opening is 55mm I'll check my 71 clubby and see if it's the same later on
Author:  simo74 [ Tue Jan 27, 2015 7:44 pm ]
badges held fast with the little plastic retainers and didn't want to pry them out. Measured to the edge. Not sure if these will be useful if not.
Author:  doogie [ Tue Jan 27, 2015 10:15 pm ]
Thanks sumo, just what i needed.
Doogie
Author:  simo74 [ Wed Jan 28, 2015 7:35 am ]
No worries glad to be of help
