It is currently Fri Jul 18, 2025 2:20 pm
PostPosted: Thu Jan 29, 2015 9:50 pm
HI guys, got most the car stripped and trying to prise the pulley off to do the timing cover gasket that is leaking.. how hard or is there a trick to removing the pulley?
Cheers Brett
PostPosted: Thu Jan 29, 2015 9:55 pm
2 screwdrivers works unless it's been Loctited on. Then you might need a puller.
PostPosted: Thu Jan 29, 2015 9:57 pm
Thanks mate.... will try tomorrow. I presume on different parts..
PostPosted: Fri Jan 30, 2015 6:27 pm
when I had a stubborn one I drilled 2 handy holes in my flywheel puller :)
PostPosted: Fri Jan 30, 2015 8:34 pm
Thanks guys, got it off and back on.. The only issue is the lower one wont tighten up. it just keeps going around and around. yes it the right size, I ended up using a special gasket maker goo, as I didn't have any timing seal gaskets... any ideas what I could do? it screws in, and when its about to torque up, it just keeps going around and around.
Cheers Brett
PostPosted: Fri Jan 30, 2015 9:06 pm
Not much room there to do in situ, but when stripped, I have drilled 17/64" then tapped 5/16" UNF in the past for a bigger bolt.
I have a right angle drill with a chopped off drill bit. 8)
PostPosted: Sat Jan 31, 2015 11:21 am
Cheers Brett
that one is a bugger because there's not much room behind it, but you can use a longer bolt and a nut on the other side - one of mine is like that, except it's the top one at the back so bolt length doesn't matter
you might be able to grind down a nut to fit in the gap
Users browsing this forum: No registered users and 116 guests
