Removal of the Timing cover Pulley https://www.ausmini.com/forums/viewtopic.php?f=2&t=88481 |
Author: | brett [ Thu Jan 29, 2015 9:50 pm ] |
Post subject: | Removal of the Timing cover Pulley |
HI guys, got most the car stripped and trying to prise the pulley off to do the timing cover gasket that is leaking.. how hard or is there a trick to removing the pulley? Cheers Brett |
Author: | drmini in aust [ Thu Jan 29, 2015 9:55 pm ] |
Post subject: | Re: Removal of the Timing cover Pulley |
2 screwdrivers works unless it's been Loctited on. Then you might need a puller. |
Author: | brett [ Thu Jan 29, 2015 9:57 pm ] |
Thanks mate.... will try tomorrow. I presume on different parts.. |
Author: | simon k [ Fri Jan 30, 2015 6:27 pm ] |
when I had a stubborn one I drilled 2 handy holes in my flywheel puller ![]() |
Author: | brett [ Fri Jan 30, 2015 8:34 pm ] |
Thanks guys, got it off and back on.. The only issue is the lower one wont tighten up. it just keeps going around and around. yes it the right size, I ended up using a special gasket maker goo, as I didn't have any timing seal gaskets... any ideas what I could do? it screws in, and when its about to torque up, it just keeps going around and around. Cheers Brett |
Author: | drmini in aust [ Fri Jan 30, 2015 9:06 pm ] |
Not much room there to do in situ, but when stripped, I have drilled 17/64" then tapped 5/16" UNF in the past for a bigger bolt. I have a right angle drill with a chopped off drill bit. ![]() |
Author: | simon k [ Sat Jan 31, 2015 11:21 am ] |
brett wrote: Thanks guys, got it off and back on.. The only issue is the lower one wont tighten up. it just keeps going around and around. yes it the right size, I ended up using a special gasket maker goo, as I didn't have any timing seal gaskets... any ideas what I could do? it screws in, and when its about to torque up, it just keeps going around and around. Cheers Brett that one is a bugger because there's not much room behind it, but you can use a longer bolt and a nut on the other side - one of mine is like that, except it's the top one at the back so bolt length doesn't matter you might be able to grind down a nut to fit in the gap |
