It is currently Sat Jul 19, 2025 3:40 pm
 Post subject: Exhaust system kit
PostPosted: Sun Feb 01, 2015 3:41 pm
Hi,
Has anyone had any experience fitting a pre manufactured exhaust system kit?
Do they generally fit well or am I better of taking my mini to an exhaust specialist & having one custom made and fit?
Thanks
Dave
 Post subject: Re: Exhaust system kit
PostPosted: Sun Feb 01, 2015 4:07 pm
I got mine from mini spares UK. I got all stainless system for around the same price as made up mild steel one here. Fitted perfectly and. It's shiney 8)
PostPosted: Sun Feb 01, 2015 4:20 pm
I've fitted 2 exhaust systems to both of my cars.
First car was a single box RC40 with new maniflow 3-1 extractors. All fitted together and bolted up very well. I am very happy with this setup and would recommend it.
Second car I fitted a twin box RC40 to a set of LCB extractors I already had. Not so easy job trying to get the old extractors to mate up to the new exhaust. I ended up having to get and weld up an exhaust flange gasket to make the join work. Not a fun job welding up the flange gasket to the extractors on the car.
1963 Morris 850
PostPosted: Sun Feb 01, 2015 4:27 pm
Just out of interest did you prefer the single or twin box?
PostPosted: Sun Feb 01, 2015 4:34 pm
Single box on the 998. Twin box on the 1275. Prefer the single box any day.
1963 Morris 850
PostPosted: Sun Feb 01, 2015 4:50 pm
Only trouble I've ever had is fitting local garage bent pipes...those ones often don't quite fit...
PostPosted: Sun Feb 01, 2015 5:01 pm
I fitted this kit below
http://maniflow.co.uk/index.php?view=pr ... oduct=1388
fits awesome and sounds great! Includes a few cool upgrades too :D
James
PostPosted: Tue Feb 03, 2015 8:45 am
Thanks everyone for the info. James how noisy is the system you fitted? I want a nice note but not too noisy in the cabin. I would be fitting it to a 1098.
PostPosted: Tue Feb 03, 2015 8:59 am
We fitted a Maniflow med bore LCB an an RC40 twin box to Laingy's 1377 van.
The engine pipe was a Cooper to RC40 one, so we had to cut the swaged end & bend off the front, and the 30deg bend off the back.
Fitted together fine then, but the RC40 tailpipe wasn't long enough to reach the van's longer rear. So I welded a bit of polished S/S pipe to it.
PostPosted: Tue Feb 03, 2015 9:21 am
I fitted this one to my 998. It was about $420 delivered a couple of months ago (although the exchange rate has changed since then). The twin box exhaust is a bit quiet in my opinion. It fitted great, except that the pipe was arcing onto the floor starter button! Just needed a little massaging to get it right.
http://www.minispares.com/product/Class ... STN17.aspx
PostPosted: Tue Feb 03, 2015 12:48 pm
I have a standard RC40 exhaust and LCB extractors on my clubby. The exhaust is great, but I wouldn't recommend LCBs for a small bore (at least, not the ones I have). The y-piece is the lowest point of the body, and it bangs on everything.
PostPosted: Tue Feb 03, 2015 12:59 pm
The 1275 blocks are taller, so the LCB's tend to fit better on them
PostPosted: Thu Feb 05, 2015 8:28 pm
I wouldn't say it's overly loud at all in the cabin. Under acceleration it has a nice subtle rasp out the back. Maniflow make great quality products
Users browsing this forum: No registered users and 67 guests
