Exhaust system kit https://www.ausmini.com/forums/viewtopic.php?f=2&t=88499 |
Author: | DCR [ Sun Feb 01, 2015 3:41 pm ] |
Post subject: | Exhaust system kit |
Hi, Has anyone had any experience fitting a pre manufactured exhaust system kit? Do they generally fit well or am I better of taking my mini to an exhaust specialist & having one custom made and fit? Thanks Dave |
Author: | peterb [ Sun Feb 01, 2015 4:07 pm ] |
Post subject: | Re: Exhaust system kit |
I got mine from mini spares UK. I got all stainless system for around the same price as made up mild steel one here. Fitted perfectly and. It's shiney ![]() |
Author: | mini0998 [ Sun Feb 01, 2015 4:20 pm ] |
I've fitted 2 exhaust systems to both of my cars. First car was a single box RC40 with new maniflow 3-1 extractors. All fitted together and bolted up very well. I am very happy with this setup and would recommend it. Second car I fitted a twin box RC40 to a set of LCB extractors I already had. Not so easy job trying to get the old extractors to mate up to the new exhaust. I ended up having to get and weld up an exhaust flange gasket to make the join work. Not a fun job welding up the flange gasket to the extractors on the car. |
Author: | sako [ Sun Feb 01, 2015 4:27 pm ] |
Just out of interest did you prefer the single or twin box? |
Author: | mini0998 [ Sun Feb 01, 2015 4:34 pm ] |
Single box on the 998. Twin box on the 1275. Prefer the single box any day. |
Author: | Mick [ Sun Feb 01, 2015 4:50 pm ] |
Only trouble I've ever had is fitting local garage bent pipes...those ones often don't quite fit... |
Author: | jprior2912 [ Sun Feb 01, 2015 5:01 pm ] |
I fitted this kit below http://maniflow.co.uk/index.php?view=pr ... oduct=1388 fits awesome and sounds great! Includes a few cool upgrades too ![]() James |
Author: | DCR [ Tue Feb 03, 2015 8:45 am ] |
Thanks everyone for the info. James how noisy is the system you fitted? I want a nice note but not too noisy in the cabin. I would be fitting it to a 1098. |
Author: | drmini in aust [ Tue Feb 03, 2015 8:59 am ] |
We fitted a Maniflow med bore LCB an an RC40 twin box to Laingy's 1377 van. The engine pipe was a Cooper to RC40 one, so we had to cut the swaged end & bend off the front, and the 30deg bend off the back. Fitted together fine then, but the RC40 tailpipe wasn't long enough to reach the van's longer rear. So I welded a bit of polished S/S pipe to it. |
Author: | timmy201 [ Tue Feb 03, 2015 9:21 am ] |
I fitted this one to my 998. It was about $420 delivered a couple of months ago (although the exchange rate has changed since then). The twin box exhaust is a bit quiet in my opinion. It fitted great, except that the pipe was arcing onto the floor starter button! Just needed a little massaging to get it right. http://www.minispares.com/product/Class ... STN17.aspx |
Author: | Irish Yobbo [ Tue Feb 03, 2015 12:48 pm ] |
I have a standard RC40 exhaust and LCB extractors on my clubby. The exhaust is great, but I wouldn't recommend LCBs for a small bore (at least, not the ones I have). The y-piece is the lowest point of the body, and it bangs on everything. |
Author: | timmy201 [ Tue Feb 03, 2015 12:59 pm ] |
Irish Yobbo wrote: I have a standard RC40 exhaust and LCB extractors on my clubby. The exhaust is great, but I wouldn't recommend LCBs for a small bore (at least, not the ones I have). The y-piece is the lowest point of the body, and it bangs on everything. The 1275 blocks are taller, so the LCB's tend to fit better on them |
Author: | jprior2912 [ Thu Feb 05, 2015 8:28 pm ] |
DCR wrote: Thanks everyone for the info. James how noisy is the system you fitted? I want a nice note but not too noisy in the cabin. I would be fitting it to a 1098. I wouldn't say it's overly loud at all in the cabin. Under acceleration it has a nice subtle rasp out the back. Maniflow make great quality products |
