It is currently Sun Jul 20, 2025 3:10 pm
PostPosted: Mon Feb 02, 2015 8:33 pm
Greetings All.
Bought a 12A408 Thermostat housing as this has a thread for a temperature switch. I'm fitting a Thermo fan.
The kit came with a 70c switch, which is way too early, and also a different thread (probably metric).
What thread is the 850 12A408 housing?? Is it 3/8 BSP???
Any ideas where to get a switch, the right thread and cuts in at (say) 90c
Alex.
PostPosted: Mon Feb 02, 2015 8:46 pm
more likely to be 5/8 UNF - take it to a bolt shop and they'll tell you
PostPosted: Tue Feb 03, 2015 5:13 pm
Thanks Simon.
Went to Repco and they sent me to another place (Shipways)
Turns out they are M16 with a 1.5 pitch.
Obviously made for modern senders / switches.
I had a Mitsubishi Magna switch which fits perfectly.
Now I can look for a new switch.
Alex.
PostPosted: Thu Feb 05, 2015 7:31 am
I hate how they now put metric threads in aftermarket Mini stuff.
Case in point, new spin-on oil filter housing. The thread `appears' to be M14, good luck screwing the oil pipe flare nipple in properly. M14 ain't the same as 1/4 BSP....! You might get 2 threads engagement.
