iamstib wrote:
Yeah minisport aus and karcraft sell the minispares one... no one seems to sell the minisport one so maybe thats the dodgy one?
minispares/karcaft sell 3 diff ones. Is the one with the spherical joint arm better then the other?
Spherical joint lower arms are for racing. They were illegal for road use, and maybe still are.
Minispares adjustable bottom arms with the rubbers work OK, but IMO the earlier type with tube and 2 locknuts was stronger. MUCH bigger thread.
An alternative for road use is 1.5deg -ve camber bottom arms. That's what I run now.
In my previous reply I took `camber kits' to mean the adjustable rear brackets, I was not referring to bottom arms.
