Under bonnet heater mounting https://www.ausmini.com/forums/viewtopic.php?f=2&t=88535 |
Author: | mini_fanatic [ Fri Feb 06, 2015 7:14 am ] |
Post subject: | Under bonnet heater mounting |
Looking at fitting an under bonnet heater in a '67 Deluxe (it's previously had one), but discovered that there's two types of heaters/mountings: 3 bolt mounts, or 2 bolts and a rubber. Would anyone have a photo of the body mount/bolt that goes with the rubber? Found a post from drmini saying its a "wide |_| bolt", but not sure exactly what it looks like? Also, which sort would have likely been fitted in a mid-late 1967 Deluxe? There's a few holes in the inner guard, but looking like it lines up for the 3 bolt style. Evan (sorry for the poor photo, rubber mount on the left, 3 bolt on the right.) |
Author: | drmini in aust [ Fri Feb 06, 2015 7:40 am ] |
Post subject: | Re: Under bonnet heater mounting |
It is just a U-bolt, with the middle bit flat not curved so it goes thru the vee in the rubber-, ie has 2 90deg bends in it. I think it is 5/16" dia? I'll check that shortly. [edit] NO, it has 1/4 thread on the ends, In the car, I can't see if the whole bolt is 1/4" dia with 2 flat washers on, or if it's 5/16" bar with the ends turned down to a shoulder. Check the size of the vee in your rubber mount. |
Author: | mini_fanatic [ Fri Feb 06, 2015 11:44 am ] |
Thanks drmini, that's great. Never seen one of them before, will have to keep an eye out. I bet the heater is a lot easier to install with that rather than the third bolt type! |
Author: | drmini in aust [ Fri Feb 06, 2015 3:37 pm ] |
Yep it comes out in 5 mins flat. That vee rubber is the same as used on a Moke bonnet hinge (I think). |
Author: | jubblies [ Fri Feb 06, 2015 7:40 pm ] |
This is the bracket. ![]() |
Author: | jubblies [ Fri Feb 06, 2015 7:42 pm ] |
This is the heater part ![]() |
Author: | mini_fanatic [ Mon Feb 09, 2015 6:30 am ] |
Thanks Justin, that's fantastic. I don't recall ever seeing one. Unfortunately looking at the inner guard, it must have had the early 3-bolt heater ![]() Evan |
Author: | peterb [ Mon Feb 09, 2015 6:58 am ] |
The little rubber is the same as bonnet rod holder on early models, still available. 2H9215 |
