Does anyone know the tpk for 200kmph cooper s speedo https://www.ausmini.com/forums/viewtopic.php?f=2&t=88547 |
Author: | Lindsay_Palmer [ Sat Feb 07, 2015 8:12 am ] |
Post subject: | Does anyone know the tpk for 200kmph cooper s speedo |
Does anyone know the turns per kilometer for the 200 kmph cooper s speedo in the link below? http://minisport.com.au/cooper-s-speedo-200km-smiths I'm trying to work out which speedo drive gears I need. |
Author: | drmini in aust [ Sat Feb 07, 2015 9:07 am ] |
Post subject: | Re: Does anyone know the tpk for 200kmph cooper s speedo |
It's made for a Cooper S with 3.444 diff, I run one in mine. So, TPM would be 1280, therefore TPKm would be ~790. You just need std early (pre-1980) speedo gears 6T/17T I'm putting a 140KMH Moke one in mine instead, it is 800TPKm. Reason I'm changing- the 200KMH one is reading slower as it gets older, however the odometer is still correct. ![]() |
Author: | Lindsay_Palmer [ Sat Feb 07, 2015 12:19 pm ] |
drmini in aust wrote: It's made for a Cooper S with 3.444 diff, I run one in mine. So, TPM would be 1280, therefore TPKm would be ~790. You just need std early (pre-1980) speedo gears 6T/17T I'm putting a 140KMH Moke one in mine instead, it is 800TPKm. Reason I'm changing- the 200KMH one is reading slower as it gets older, however the odometer is still correct. ![]() Thanks, I'm running 12 inch wheels and 2.76 diff gears so I'll need to do some Maths. |
Author: | jprior2912 [ Sat Feb 07, 2015 12:28 pm ] |
Hi there Try using this calculator, it was very accurate when I used it. http://www.guess-works.com/Tech/ratio.htm regards James |
Author: | Lindsay_Palmer [ Sat Feb 07, 2015 12:32 pm ] |
jprior2912 wrote: Hi there Try using this calculator, it was very accurate when I used it. http://www.guess-works.com/Tech/ratio.htm regards James That's what I am using. They now list the speedo I'm using. |
