Inlet manifold https://www.ausmini.com/forums/viewtopic.php?f=2&t=88555 |
Author: | drmini in aust [ Sat Feb 07, 2015 6:12 pm ] |
Post subject: | Re: Inlet manifold |
A Minispares single HS4/HS6 manifold fits, however you will probably not be able to run the donut air filter. Fit a Ramflo, K&N or similar sports filter. Here's my 1412 stroker with a 20mm thick spacer on it: ![]() |
Author: | Phil 850 [ Sat Feb 07, 2015 6:45 pm ] |
Is there a significant benefit of the Minispares manifold over the Leyland even if the leyland one is ported as DVD A Series book. |
Author: | drmini in aust [ Sat Feb 07, 2015 9:12 pm ] |
A lot less work to fit, and they are pretty cheap to buy, even here. I'd say they will outflow a ported stock HS4 one. |
Author: | VulcanBB18 [ Sun Feb 08, 2015 7:31 am ] |
That's NOT a stock HS4 cast iron manifold. That looks like the MG metro manifold, it's alloy and flows pretty well according to Viz. I doubt you'd get much (if anything) going to a minispares manifold over that. cheers, Jacob |
Author: | 1071 S [ Sun Feb 08, 2015 8:09 am ] |
Looks the same as the one I bought second hand from the UK. And you can see the grooves in the photo that indicate that a 44 (1 3/4) has been previously bolted up. Mine looked as nice inside as the much shinier (and expensive) Mspares version... Cheers, Ian |
Author: | Mokesta [ Sun Feb 08, 2015 7:35 pm ] |
Looks like the MG Metro manifold. Build for the HIF6 and flows very well. No need to change. M |
