It is currently Sun Jul 20, 2025 8:33 am
PostPosted: Thu Feb 19, 2015 11:30 pm
What combination of engine & gearbox steady's are recommended for arod change box?
clutch side engine steady & two lower gearbox steady's or two upper engine steady's & a single lower one?
PostPosted: Fri Feb 20, 2015 4:54 am
I use 2 top ones and 1 lower one under the clutch. Never had a problem
PostPosted: Fri Feb 20, 2015 7:04 am
I would be interested to know where you sourced that shorter adjustable radiator side engine steady.
PostPosted: Fri Feb 20, 2015 7:13 am
I made it myself out of an original one. Cut and threaded it , and made the threaded tube.
PostPosted: Fri Feb 20, 2015 7:29 am
Josh, I can make you one. I did one recently for Laingy's van.
PostPosted: Fri Feb 20, 2015 7:50 am
http://www.minispares.com/product/Class ... 0to%20shop
Can buy them too.
PostPosted: Fri Feb 20, 2015 7:57 am
Does the lower steady make much difference? I've only ever had the top two (as they came from the factory, I think).
PostPosted: Fri Feb 20, 2015 8:05 am
With 2 top steadies you will still get a horizontal force reaction through the engine mounts due to engine torque.
Adding a lower one overcomes this.
PostPosted: Fri Feb 20, 2015 8:06 am
But what difference does that make for the driver?
PostPosted: Fri Feb 20, 2015 8:35 am
I cant tell any difference as a driver whether the lower steady is fitted or not, but it sure saves chewing out the engine mount under the clutch!
PostPosted: Fri Feb 20, 2015 8:52 am
Probably not an issue with the mountains of torque generated by my 998 :)
PostPosted: Fri Feb 20, 2015 9:34 am
Way back in the early 60s when all we could buy was an 850 with the magic wand gearshift (except the well heeled who could afford a 997 Cooper) it was common to fit a lower steady. Mine had it on the radiator side, not the clutch.
It helped a lot, you really needed it if fitting extractors.
PostPosted: Fri Feb 20, 2015 7:48 pm
With my rod change box - I use the 2 top steadies + 2 lower steadies from minispares, I was using the poly bushes in them too but was just too stiff. The engine sits in nice and tight and doesn't move around at all
James
PostPosted: Sat Feb 21, 2015 8:52 pm
With the MG Metro engine in my Moke the HIF float chamber was always bouncing off the firewall. That was with 2 upper steadies and a lower clutch side one.
A combination of Matt Read steady bushes, those minispares adjustable rods and a thinner carby spacer finally sorted it.
PostPosted: Sat Feb 21, 2015 9:13 pm
Just to be different I have a single top steady and two lower ones - been going for 3 years not a problem.
In my other mini I had 2 uppers and one lower but the upper one on the radiator side kept cracking the bracket or the firewall.
