Painting, sealing under car.
https://www.ausmini.com/forums/viewtopic.php?f=2&t=88631
Page 1 of 2
Author:  milton s [ Mon Feb 16, 2015 9:40 am ]
Post subject:  Painting, sealing under car.
Ok, i'm looking for some ideas. I have some small holes in the floor. I want to find a paint that I can use under the car that will seal these holes. I want to be able to brush it on as spraying will be to hard, messy. The car has just had a re spray and i don't want to risk the finish. It needs to be the car colour, crystal white.
Also i need to get all the old paint off.
Any ideas anyone :?
Matt.
Author:  Hobson [ Mon Feb 16, 2015 10:57 am ]
Post subject:  Re: Painting, sealing under car.
Just a thought
http://busnbug.com/sb_clients/busnbug/b ... or_wax.cfm
Author:  VanMorrison [ Mon Feb 16, 2015 3:37 pm ]
I'll be using .. http://www.lizardskin.com using both products as per spec.
Author:  Aussie Brian [ Mon Feb 16, 2015 4:03 pm ]
or another option....
http://www.u-pol.co.uk/product-cat/83/raptor™-bed-liner.htm
If these are way off the mark just go with some polyurethane adhesive sealant like Sikaflex in a white then just touch up with your correct colour when dry............Simple :)
Author:  mickmini [ Mon Feb 16, 2015 6:45 pm ]
Any ideas anyone :?
Matt.
Don't you want to make sure there is no loss of structural inegrity due to the rust that formed the holes first?
And rust proof it all before putting a cover up sealer on it?
Author:  milton s [ Tue Feb 17, 2015 2:17 pm ]
Thanks everyone, all those suggestions gave me something to think about. Yeah Mickmini you're 100% right, so after doing a little more research I think I like the POR15 products. The floor certainly looks strucually sound but I guess I won't know until all the old paint comes off which will give the POR15 rust preventive paint a good bond, then i can go over with the POR15 White Coat.
I've used the POR15 Fuel tank repair kit on the inside of my tanks and am extremely happy with the results, so I reckon the other products will do the job. It will look the goods any way.
Here's hoping i find no rust, don't know what i'll do if there is. Don't even want to think about it. :cry:
Matt.
Author:  Morbo28 [ Tue Feb 17, 2015 8:55 pm ]
+1 POR 15 is what I would use
Author:  winabbey [ Mon Mar 23, 2015 1:49 pm ]
Milton - you need to use the IMG link in Photobucket to have the images displayed, like below. This is the first of your images. I'll leave it to you to do the rest.
Author:  milton s [ Mon Mar 23, 2015 3:55 pm ]
Thanks so much Winabbey we will be on to that as soon as the IT expert gets home from work.
Ha maybe one day i'll be able to do this on my own.
Matt.
Author:  milton s [ Mon Mar 23, 2015 5:44 pm ]
In Winabbey's post is a photo of my car and hopefully here are some before and after of the underside. The stripped photo is when it was prepped with the por 15 metal ready treatment and ready to undercoat, then there is a photo of the finished product. I think it came up really well. The floor is solid as, no rust.
Author:  Mick [ Mon Mar 23, 2015 5:54 pm ]
That's some hard work right there. Came up a treat. Where do you think the holes came from? Dents or corrosion?
Author:  gtogreen1969 [ Mon Mar 23, 2015 6:56 pm ]
She is a nice looking car.
Author:  milton s [ Tue Mar 24, 2015 2:23 pm ]
Thanks gtogreen, i'm really liking that photo of the top side its a good angle.
And Mick, the holes or hole, definitely not rust. There was some damage to the floor around were the wheel arch met the floor,not bad damage but possible source. The other place were water came from was the the recess for the jack. So i made sure i got some sika body sealer in there and painted over it.
I think those covers look good black! I'm trying to work out now how to wash under the car, haha.
Matt.
Author:  niffty64 [ Tue Mar 24, 2015 4:04 pm ]
the floor came up fantastic.
awesome looking Car. Matt
Author:  slacko [ Tue Mar 24, 2015 6:04 pm ]
Well done Matt
came up really nice
Mark
