It is currently Fri Jul 18, 2025 5:50 pm
PostPosted: Sun Feb 15, 2015 12:50 pm
Hey everyone
So I've a leak coming from the bottom of the timing cover so was going to change the gasket...
I've got the right size socket for it but I can't for the life of me get it undone! My mechanic suggested having the socket there and turning the car over but that didn't undo it... Is there any tricks to getting this undone?
the head is still off the car btw (not sure it that makes a difference) When I try undoing it the engine just turns
Regards
James
PostPosted: Sun Feb 15, 2015 12:57 pm
Plan A:
Pull the starter out then sit an old bearing shell in the ring gear. It will stay there whilst you apply 1-5/16" socket + BIG breaker bar to the crank pulley nut. (it should be around 75 ft/lb torque).
Some people hold a big screwdriver into the ring gear but it's likely to slip.
Plan B:
Fit 1-5/16" socket & breaker bar to pulley nut, hold the bar against firewall. Crank starter...
PostPosted: Sun Feb 15, 2015 1:09 pm
I would just remove the starter and use a slim spanner in the ringear up against the casing and use a breaker bar on the bolt.
Although Plan C:
Select 4th gear and apply handbrake and use breaker bar.
PostPosted: Sun Feb 15, 2015 1:57 pm
I think I have always used a small spanner in between the primary cover and the ringear after removing the starter motor.
PostPosted: Sun Feb 15, 2015 2:58 pm
Thanks everyone for the suggestions
Didn't have an old bearing shell so I gave a screwdriver a go. POP! worked a charm. Thread had Loctite on it as well so that made it a bit more stubborn. Not surprised the gasket was leaking after seeing the gasket that was used by my "engine specialist" *rolls eyes*
PostPosted: Mon Feb 16, 2015 9:43 am
(this has been said before by others)
For those with the head still on..take out no1 spark plug, turn engine just past compression stroke and feed in a length of poly rope. The rope offers a soft cushion and stops the piston/crank going past TDC. Nut comes loose. Actually really easy to do and fast.
(engine must be cool, might be obvious but wasn't for me (once))
PostPosted: Mon Feb 16, 2015 2:53 pm
As well as replacing the gasket you should also replace the oil seal.
Tip: when replacing the timing cover, put all of the bolts in loosely then slip the harmonic balancer/pulley back onto the end of the crankshaft so as to align the oil seal and timing cover.
Then when happy that it is centred then tighten up the bolts.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Mon Feb 16, 2015 4:11 pm
Nice tip MB
PostPosted: Mon Feb 16, 2015 7:20 pm
Cheers Michael
Got that tip today! Handy thing to know.
James
Users browsing this forum: No registered users and 112 guests
