It is currently Fri Jul 25, 2025 12:42 pm
PostPosted: Thu Feb 19, 2015 3:52 pm
Hey all you gearbox experts.
Just wonding if I can change a 4 synco gear set from a rod change box into a 3 syncro remote housing??
Cheers in advance.
Rodney
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Thu Feb 19, 2015 4:09 pm
Rodney, pretty sure lay shafts are different, do u need a 4 syc casing ?
mal
PostPosted: Thu Feb 19, 2015 4:19 pm
Yeah I will swap the layshaft too.
The new mini has a rod change and due to the supercharger only has 1 top engine steady so im worried about the engine rocking.
I gave heaps of 4 synco rod change housings here but really want it to be remote
The rod change box in the new car is freshly rebuilt .
Rodney
Minis..
1975 van
PostPosted: Thu Feb 19, 2015 4:24 pm
Short answer is no...
If you get a clean/stripped case you'll need the remote reverse gear as well as all the gear shift gubbin's.
PostPosted: Thu Feb 19, 2015 4:29 pm
Rodney, I should have a 998 4 sync remote , only issue is you will need to grid to suit 1275 crank, easily done as per Vizard tuning book, I will have a look tonight.
you could also just fit bottom steady bars, mini spares or KAD do them
Mal
PostPosted: Thu Feb 19, 2015 5:48 pm
Mal
A 1275 will fit onto any 4 synchro remote box, either 22G1128 or 22G846, should be no grinding needed.
re the previous question, NO the rodchange gears won't fit any 3 synchro box. But they will fit in a 4 synchro remote box, layshaft and all. The reverse gear is different though, use the remote box one..
PostPosted: Thu Feb 19, 2015 5:55 pm
Will get in touch with you soon malcom. Cheers.
Minis..
1975 van
PostPosted: Thu Feb 19, 2015 6:28 pm
See if the engine steady ben makes for the SC12 can fit with that setup
PostPosted: Thu Feb 19, 2015 10:08 pm
Any ideas what this Gear Box is from, casting number looks like 22G845, doesn't match any normal mini number
It's a 4 sync remote that I have been running on my mini for a couple of years , can't remember where I got it from.
PostPosted: Thu Feb 19, 2015 10:14 pm
That's a 22G846, as I mentioned above.
Functionally the same as a 22G1128 4 synchro remote box.
PostPosted: Thu Feb 19, 2015 10:18 pm
sorry, how did I miss that, thanks doc
