4 syncro rodchange gear set into remote housing.
https://www.ausmini.com/forums/viewtopic.php?f=2&t=88666
Author:  boomini [ Thu Feb 19, 2015 3:52 pm ]
Post subject:  4 syncro rodchange gear set into remote housing.
Hey all you gearbox experts.
Just wonding if I can change a 4 synco gear set from a rod change box into a 3 syncro remote housing??
Cheers in advance.
Rodney
Author:  69cooper [ Thu Feb 19, 2015 4:09 pm ]
Post subject:  Re: 4 syncro rodchange gear set into remote housing.
Rodney, pretty sure lay shafts are different, do u need a 4 syc casing ?
mal
Author:  boomini [ Thu Feb 19, 2015 4:19 pm ]
Yeah I will swap the layshaft too.
The new mini has a rod change and due to the supercharger only has 1 top engine steady so im worried about the engine rocking.
I gave heaps of 4 synco rod change housings here but really want it to be remote
The rod change box in the new car is freshly rebuilt .
Rodney
Author:  ba_dm_tsh [ Thu Feb 19, 2015 4:24 pm ]
Short answer is no...
If you get a clean/stripped case you'll need the remote reverse gear as well as all the gear shift gubbin's.
Author:  69cooper [ Thu Feb 19, 2015 4:29 pm ]
Rodney, I should have a 998 4 sync remote , only issue is you will need to grid to suit 1275 crank, easily done as per Vizard tuning book, I will have a look tonight.
you could also just fit bottom steady bars, mini spares or KAD do them
Mal
Author:  drmini in aust [ Thu Feb 19, 2015 5:48 pm ]
Mal
A 1275 will fit onto any 4 synchro remote box, either 22G1128 or 22G846, should be no grinding needed.
re the previous question, NO the rodchange gears won't fit any 3 synchro box. But they will fit in a 4 synchro remote box, layshaft and all. The reverse gear is different though, use the remote box one..
Author:  boomini [ Thu Feb 19, 2015 5:55 pm ]
Will get in touch with you soon malcom. Cheers.
Author:  mini_mad_matt [ Thu Feb 19, 2015 6:28 pm ]
See if the engine steady ben makes for the SC12 can fit with that setup
Author:  69cooper [ Thu Feb 19, 2015 10:08 pm ]
Any ideas what this Gear Box is from, casting number looks like 22G845, doesn't match any normal mini number
It's a 4 sync remote that I have been running on my mini for a couple of years , can't remember where I got it from.
Author:  drmini in aust [ Thu Feb 19, 2015 10:14 pm ]
That's a 22G846, as I mentioned above.
Functionally the same as a 22G1128 4 synchro remote box.
Author:  69cooper [ Thu Feb 19, 2015 10:18 pm ]
sorry, how did I miss that, thanks doc
