Which way does the crank pulley spacer thing go on? https://www.ausmini.com/forums/viewtopic.php?f=2&t=88677 |
Author: | jprior2912 [ Sat Feb 21, 2015 1:04 pm ] |
Post subject: | Which way does the crank pulley spacer thing go on? |
Hi everyone Was cleaning around the timing gear to refit the gasket and cover when I accidentally knocked the round spacer that was siting on the pulley shaft. It has like an indent on the inner ring, so does it sit so the indent is rad/pulley side or does it sit so the further out bit sits next to the block? ![]() Seems like a stupid question but I have to get it right! Cheers James |
Author: | drmini in aust [ Sat Feb 21, 2015 1:24 pm ] |
Post subject: | Re: Which way does the crank pulley spacer thing go on? |
The convex face you can see above goes outwards. |
Author: | jprior2912 [ Sat Feb 21, 2015 1:32 pm ] |
drmini in aust wrote: The convex face you can see above goes outwards. Thanks doc - except that's the concave bit in the photo haha ![]() |
Author: | TheMiniMan [ Sat Feb 21, 2015 1:46 pm ] |
yes the other way round ![]() should be an "F" on the convex side, means "Front" |
Author: | drmini in aust [ Sat Feb 21, 2015 1:55 pm ] |
TheMiniMan wrote: yes the other way round ![]() should be an "F" on the convex side, means "Front" Sorry yeah my bad, didn't have specs on. It is concave there, ain't it! ![]() Duplex ones have F marked on em, I dunno about the deeper simplex ones like yours. |
Author: | jprior2912 [ Sat Feb 21, 2015 2:06 pm ] |
drmini in aust wrote: TheMiniMan wrote: yes the other way round ![]() should be an "F" on the convex side, means "Front" Sorry yeah my bad, didn't have specs on. It is concave there, ain't it! ![]() Duplex ones have F marked on em, I dunno about the deeper simplex ones like yours. Cheers guys Mine looks as though it has an L stamped into the convex side. (single chain) |
Author: | Convertible Mini [ Sat Feb 21, 2015 7:09 pm ] |
It is called an oil slinger.. |
Author: | drmini in aust [ Sun Feb 22, 2015 8:08 am ] |
Just so you know, there are 2 types of slinger. The one you have will only fit with a single row (simplex) chain. There is also a flatter one that is made for a duplex chain, but will fit with either. |
