Clutch slave travel
https://www.ausmini.com/forums/viewtopic.php?f=2&t=88682
Author:  ba_dm_tsh [ Sat Feb 21, 2015 10:45 pm ]
Post subject:  Clutch slave travel
Hi all,
Just wondering if anyone with a tiptop pre-verto clutch system could do me a solid and measure the total travel in the slave cylinder when the clutch pedal is pushed (so, how far the end of the pushrod moves)?
Thanks!
Author:  Bill B [ Sun Feb 22, 2015 2:12 pm ]
Post subject:  Re: Clutch slave travel
The full throw of a new/good clutch slave cylinder pushrod is 19-21mm (on '69-'70 clutch). Check that when you are measuring that travel, there is a clearance between the head of the adjustment stop screw and the clutch lever.
Hope that's clear...
Bill
Author:  ba_dm_tsh [ Sun Feb 22, 2015 7:22 pm ]
Thanks for that Bill :-)
Author:  peterb [ Mon Feb 23, 2015 7:28 am ]
We used to, and I still do, throw the slave cylinder return spring away. It then makes clutch 'self adjusting', been doing that for about 40 years, never had a problem.
Author:  Bill B [ Wed Feb 25, 2015 8:46 pm ]
Sorry to hijack the original question although it seems to have been answered. So, without the return spring, what effect does that have on the feel of the clutch pedal? I broke a spring once and the pedal felt very soft. Should that be the effect?
Bill
Author:  1071 S [ Wed Feb 25, 2015 8:50 pm ]
IMHO...no.
Having got rid of the spring I can't say I've noticed a difference..
Cheers, Ian
Author:  RNY997 [ Wed Feb 25, 2015 9:30 pm ]
Without the spring the release bearing will contact or spin with flywheel all the time.
Other than that it shouldnt feel any different
Author:  Diesel27 [ Wed Feb 25, 2015 10:45 pm ]
Bleed first.
