It is currently Sat Jul 19, 2025 4:23 pm
PostPosted: Tue Jan 28, 2014 3:42 pm
I've pulled off my old chrome moulding and I'm ready to put the new ones back on... but it's obviously a bit hard to form.
Do I just start from one side (rivet it down?) and then heat gun it slowly across until it moulds to the right shape? Or is there another method for this? If the heat gun is the right way, would I mould it then rivet as I go, or make it all fit, then rivet it at the end?
Also with rivets, is there a craftsmanship trick to it (like every x cm apart) or should I just use the original holes and drill from underneath?
PostPosted: Tue Jan 28, 2014 4:24 pm
Yes, drill from underneath, I use a hair dryer, nice and easy, and when you rivet make sure they sure it's a short grip type and pull back as you squash them so they don't touch the mould. You don't need too many, just near the curve, one at each end and one in the middle for good measure if you like.
Nice and steady :)
Thanks
Ian
850 Morris Mini
Morris Mini Traveller
Mini sports Sedan
PostPosted: Tue Jan 28, 2014 4:25 pm
This has been covered a lot on here. These are some i found
viewtopic.php?f=2&t=21592&view=next
viewtopic.php?t=51825&view=previous
viewtopic.php?p=365735
viewtopic.php?f=2&t=78568&view=previous
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Tue Jan 28, 2014 5:01 pm
Cheers for the links Ryan - I did do a google search for aus mini chrome fenders but it came up empty.
Cheers Ian - May look into stealing a hairdryer! Heat gun may be overkill here
PostPosted: Tue Jan 28, 2014 5:05 pm
a good tip for searching google is to type "site:ausmini.com" followed by the topic.
eg: site:ausmini.com chrome side trim
Ryan Filippi
Minis In The Gong
[email protected]
PostPosted: Tue Jan 28, 2014 8:15 pm
Don't heat them too much as they distort and turn into a mess.
I have found a bucket of hot water worked ok in the past but the latest plastic strip doesn't seem as good as the old stuff :?
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Tue Jan 28, 2014 8:33 pm
Hot summer sun is all you need
Was gonna do mine this week but a dam abcest on me back came up and it a no go till next week now
PostPosted: Tue Jan 28, 2014 10:17 pm
I laid mine out on the concrete drive on Saturday when it was about 37 degrees hoping to make them easier to uncurl. It worked a little but not as well as I had hoped. Having it stiff did make it hold on well after fitting though. I ended up not having to use rivets.
Behold! The mighty 850!
PostPosted: Wed Jan 29, 2014 9:20 am
This is what BMC advised:
PostPosted: Wed Jan 29, 2014 8:08 pm
Blimey! Talk about Ye Olde Instructions!
PostPosted: Wed Jan 29, 2014 8:16 pm
Thats excellent Doug , thanks .
It will be a job for me down the track somewhere as mine have started to shrink where they bend
round the flairs .
PostPosted: Wed Feb 25, 2015 2:55 pm
Just came across these instructions on the MiniMania site. Thought they might be of help.
http://www.minimania.com/Factory_trim_m ... 7___GZF105
Users browsing this forum: drmini in aust and 77 guests
