It is currently Sun Jul 20, 2025 8:31 am
PostPosted: Tue Dec 09, 2014 12:17 pm
These do look nice.. 8)
http://www.calverst.com/shop/index.php? ... cts_id=121
PostPosted: Tue Dec 09, 2014 12:43 pm
Indeed, none of that roller rubbish getting in the way of a good rocker :wink:
http://www.mini-hb.co.nz
PostPosted: Tue Dec 09, 2014 1:45 pm
Somebody should post up some good busted roller rocker pics. :twisted:
I've seen quite a few, both cheapo ones, and expensive.
I'm sure many punters get captivated by their Bling! factor, yet you can't see them once installed, haha.
PostPosted: Tue Dec 09, 2014 3:39 pm
Are you suggesting there's an opportunity there for someone to make a transparent rocker cover? :shock:
PostPosted: Tue Dec 09, 2014 4:50 pm
Making it clear is easy the hard part is keeping it clean so you can see them :?
PostPosted: Tue Dec 09, 2014 8:37 pm
For those that can remember it's a bit like Ted Bullpit polishing the dipstick in the Kingswood on the old tele show Kingswood Country
PostPosted: Tue Dec 09, 2014 8:59 pm
Showing your age now
PostPosted: Tue Dec 09, 2014 9:16 pm
I was 6yrs old when it 1st come out in 1980
PostPosted: Wed Dec 10, 2014 11:59 am
What sort of hp gain could be expected going from stock to the 1.4's?
67 Deluxe
Dry suspension
4 synchro close ratio gbox
Cooper S brakes, no booster
PostPosted: Thu Dec 11, 2014 7:28 pm
Bump! Anyone have advice on this?
Mikal
67 Deluxe
Dry suspension
PostPosted: Thu Dec 11, 2014 7:49 pm
Its like going up a cam size. It exaggerates a cam lobe to give it a little more lift. The gains would be mild if that's what you are after, short of guessing a couple of HP for the right engine....
PostPosted: Thu Dec 11, 2014 7:53 pm
What engine? Will vary greatly without knowing your engine specs.
PostPosted: Thu Dec 11, 2014 8:13 pm
Hi gtogreen,
My engine specs are at the bottom of my post. Its a big valve head with extensive porting/ polishing etc. Camshaft specs unknown but it was made by a well known engine builder who described it as "a nice road cam but good for weekend work if you want". Its definitely not a 649 which I've had, but it has good low down torque, comes on at 2500ish rpm and happily revs to 7000 which is why I descibe it as a "731 type cam". If the 1.4 rocker setup only has a few hp gain I dont see the return on investment for the price.
Mikal
67 Deluxe
Dry suspension
PostPosted: Thu Dec 11, 2014 8:39 pm
Probably only a few hp. If you are currently running forged Cooper S rockers you will see the biggest gain because they are only about 1.2 to 1 ratio. Find out what you have first. Doc has done a bit of research in the rocker department. He may be able to help you more.
PostPosted: Thu Dec 11, 2014 9:18 pm
Standard factory rockers are low on valve lift, I measured ratios of only 1.16:1 (Cooper S) to 1.21:1 (sintered) with an RE13 cam and a 1275 head.
Hi lift 1.5 rockers give more top end, but this can be at the expense of bottom end torque.
I have 1.5s in my 1360, on the chassis dyno with an RE282 sprint cam, it gave peak power at 7000-7200. There is a noticeable power surge from a bit under 5000 rpm, and then it hauls ass to 8000 if I let it.
1.4:1 rockers are a good ratio. I have modded and fitted K3 Corolla ones for a few people, these were around 1.42- 1.44:1.
[edit] typo
Last edited by drmini in aust on Fri Dec 12, 2014 6:27 am, edited 1 time in total.
Users browsing this forum: No registered users and 72 guests
