engine breather
https://www.ausmini.com/forums/viewtopic.php?f=2&t=88732
Author:  boomini [ Thu Feb 26, 2015 9:21 pm ]
Post subject:  engine breather
Hey guys another question.
So the motor in my supercharged deluxe has no crankcase breather.
Being supercharged I expect it to breath a little so where can I fit one?
The timing cover and flywheel housing out due to the supercharger setup. Is the breather on the rocker cover enough or can I fit one to the fuel pump mount.
Cheers guys
Author:  VanMorrison [ Thu Feb 26, 2015 9:40 pm ]
Post subject:  Re: engine breather
One like this..
http://www.minimania.com/part/C-2A265/C ... p-Mounting
Author:  drmini in aust [ Thu Feb 26, 2015 9:45 pm ]
That one is baffled. It might/should work.
If you make an unbaffled one like I did, it won't work. Anything over 4500rpm and the crank and rods threw heaps of oil at it. It made like JB007.
I was using an S breather on there, NO, they are not an `oil separator'. Flame trap would be a better description.
Author:  Besser [ Fri Feb 27, 2015 10:57 am ]
You can use the fuel pump hole for a breather and oil catch can return.
Author:  Tadhg [ Wed Mar 04, 2015 7:59 pm ]
I've got the Mini Mania baffled (well, sort of) breather linked mounted on my fuel pump hole. It goes to a catch can. The hose is filled with steel wool as a droplet disperser. I still get extra oil in the catch can if I rev past 4500rpm too often.
That said, I do think it's a valid place to mount a breather. Just be aware that you'll lose oil up there. And if you can put in some form of extra baffle... Do it.
Author:  michaelb [ Wed Mar 04, 2015 8:13 pm ]
What's wrong with the flywheel housing?
What type of Supercharger kit do you have?
I have a Smiffy bits breather on the flywheel housing and a VMAXSCART kit with Eaton supercharger.
