rear lights work on parkers - not on low beam https://www.ausmini.com/forums/viewtopic.php?f=2&t=88733 |
Author: | Garagedefend [ Thu Feb 26, 2015 11:03 pm ] |
Post subject: | rear lights work on parkers - not on low beam |
so earlier I noticed that when I have the light switch on parkers the rear lights and license plate lights work. when I have it on low/high beam none of the rear lights work. The indicators do and the brake lights do but only when I step on the brakes... what gives?!?!?! has the prince of darkness struck? lol was trying to fiddle with the wires to the switch but its 12am and my flashlight has run out of battery :/ I will try again tomorrow. but anything to check in particular? |
Author: | simon k [ Fri Feb 27, 2015 9:21 am ] |
Post subject: | Re: rear lights work on parkers - not on low beam |
roundnose 2 position headlight switch, correct? there are a few terminals on the back of the switch, best to pop the switch out and use your multimeter to work out which is which and which is connected to what. This is a situation where you take a picture of the way it is set up now, and can fiddle with it to get a better understanding of the way things work. If you can't get it right, put it back the way it was in the photo and start again one (or maybe two) of them is active in both positions - IE parkers and tail lights one of them is active ONLY in the first position - IE only when the parkers are on - shouldn't be connected one of them is active ONLY in the second position - IE headlights |
Author: | Garagedefend [ Fri Feb 27, 2015 9:29 am ] |
ahhhh. I probably have it to the parkers only! I will fiddle with it later. it has off-parker-full beam |
