It is currently Sun Jul 20, 2025 6:48 pm
 Post subject: Diff question..
PostPosted: Thu Feb 26, 2015 8:15 pm
Hey guys
I have a rod change box with pot joints I'm looking to use for my van, i was told it may or may not have a lsd, is there any way to tell without having to strip it down?
Looking from the gearbox side i can see it has a standard looking crown wheel but thats about all..
Any help appreciated as i don't want to pull it apart unless i have too.
Darcy
196# Morris VAN
2013 JGC 5.7 Hemi
2012 Civic Type R
 Post subject: Re: Diff question..
PostPosted: Thu Feb 26, 2015 8:47 pm
Hi Darcy
As far as im aware if it is a open diff when you turn a pot joint with it in gear the other pot joint will turn in the other direction with little resistance.
If it is a LSD there will be a bit of resistance when turning the pot joint.
It may depend on what type of LSD is in it as to how much resistance there is
Richard
75 Panel van, 1360, RE-13, 1 3/4su
PostPosted: Thu Feb 26, 2015 8:50 pm
If it has a standard open diff you can turn either output shaft freely and the opposite side will turn the other way.
If it turns the whole diff and crown wheel its either an LSD or broken?
LSDs are not suitable for standard road use....they are hard work at the steering wheel.
....you just lost him his insurance bonus!
997
PostPosted: Thu Feb 26, 2015 9:18 pm
ok...
so i can freely do just about anything with the pot joints..
Hold one still turn the other in any direction ( works for both with a bit of resistance), turn both in opposite directions ( either way ), turn both in the same direction ( either way ).
The shifter isn't attached so I'm not sure if or how to put it into gear... :?
196# Morris VAN
2013 JGC 5.7 Hemi
2012 Civic Type R
PostPosted: Thu Feb 26, 2015 9:32 pm
Ok, sorry to say but it sounds like an open centre.
You shouldnt be able to turn the pot joints opposite ways by hand easily.
PostPosted: Thu Feb 26, 2015 9:35 pm
Sounds like an open center, it doesn't need to be in gear to check the diff.
PostPosted: Thu Feb 26, 2015 9:43 pm
so is it worth fitting an LSD in an fast road car? its not a daily driver.. I assume its not going to be like driving my type r civic...
or save the money for something else..
196# Morris VAN
2013 JGC 5.7 Hemi
2012 Civic Type R
PostPosted: Thu Feb 26, 2015 9:48 pm
If you want an LSD in a road car I'd fit a Quaife. Anything else is hard work to steer and/or won't last long.
PostPosted: Thu Feb 26, 2015 9:52 pm
i was looking at a jack knight cowl type but the more i read the more i was put off...
will look into the quaife..
196# Morris VAN
2013 JGC 5.7 Hemi
2012 Civic Type R
PostPosted: Fri Feb 27, 2015 11:34 am
I've bought the Quaife ATB upon reviews and recommendation as its meant to be unbreakable (lifetime warranty) and meant to have less torque steer than LSDs.
Sorry I won't be able to give you direct feedback for about 3 months as I'm still finishing off my build.
PostPosted: Fri Feb 27, 2015 6:42 pm
quaife ATB is great in a road car
PostPosted: Fri Feb 27, 2015 7:13 pm
But is a LSD needed in a road car ?
PostPosted: Fri Feb 27, 2015 7:50 pm
Not sure.. this isn't a daily driver so whist its a road car, its not really a road car...
196# Morris VAN
2013 JGC 5.7 Hemi
2012 Civic Type R
PostPosted: Fri Feb 27, 2015 9:30 pm
I have a quaife in mine, drives great on the road. Not cheap though, looking at 1000 bucks if you do it yourself.
PostPosted: Sat Feb 28, 2015 10:41 am
If the engine makes enough power and,
If the car is driven in such a way that causes wheel spin.
Hard acceleration during cornering or from a standing start with a std diff will just make tyre smoke and understeer, not what you want in the bendy and windy sections of a mountain range.
Users browsing this forum: No registered users and 61 guests
