Front hub Nut Split Pin https://www.ausmini.com/forums/viewtopic.php?f=2&t=88823 |
Author: | Boostedmini [ Mon Mar 09, 2015 11:03 am ] |
Post subject: | Front hub Nut Split Pin |
Hi All, Anyone know where you can get good quality split pins these days for the CV Joint/Wheel Bearing Hub Nut? every repco and car spares place dont carry them long enough and the last ones i got were very soft material and broke when i took them out... ![]() I will have to see if John @ Mini King has them. Grant |
Author: | Mick [ Mon Mar 09, 2015 11:49 am ] |
Post subject: | Re: Front hub Nut Split Pin |
I've not had problems with them myself, the nust shouldn't lean on the split pin hard enough, but I would go to CBC bearings or similar. |
Author: | bluewhitecoopers1968 [ Tue Mar 10, 2015 4:10 pm ] |
Go to an engineering supply store or similar |
Author: | drmini in aust [ Tue Mar 10, 2015 5:40 pm ] |
bluewhitecoopers1968 wrote: Go to an engineering supply store or similar Grant, Lee Bros in Dunlop St, Parramatta would have them. |
