It is currently Sat Jul 19, 2025 2:19 am
 Post subject: Indicator not flashing
PostPosted: Wed Mar 11, 2015 6:15 pm
My 62 850 decided to stop working properly. The passenger side indicators have stopped flashing, the light on the dash just lights up. On the out side the rear indicator lights up but the front indicator does not. Also when I turn the lights on all but the front passenger light up.
So I'm guessing the problem is the front light, what should I be looking for when I get around to pulling it apart :?:
PostPosted: Wed Mar 11, 2015 6:16 pm
Look at the earth on the front light.
PostPosted: Wed Mar 11, 2015 6:26 pm
Always the big four.
Check the bulb still works.
Check the fitting still works (continuity from green to black with the bulb in)
Check there is 12 volts available on the green.
Check the black still goes to ground.
