flywheel machining
https://www.ausmini.com/forums/viewtopic.php?f=2&t=88847
Author:  Diesel27 [ Wed Mar 11, 2015 7:58 pm ]
Post subject:  flywheel machining
I am going to machine my flywheel in aid of lightening it some,
can anyone please help with a bit of a not what to do if you can?
also wondering if any other mods are required?
I believe some spacers will be required in the clutch pressure plate?
Author:  Scoop [ Wed Mar 11, 2015 8:29 pm ]
Post subject:  Re: flywheel machining
I was going to do the same in a few weeks. Was going to base it on a thread I found from a while ago.
viewtopic.php?f=2&t=83379&hilit=lightening+flywheel
Author:  Diesel27 [ Wed Mar 11, 2015 8:33 pm ]
cheers Scoop, I did a search but got lost in the posts and couldnt find anything solid.
Author:  i got a mini [ Thu Mar 12, 2015 1:50 pm ]
Take note off what you machine off the flywheel, because you will have to make spacers up for the bolts so they are at the right height.
Author:  Aussie Brian [ Thu Mar 12, 2015 3:45 pm ]
I remember someone saying take 200 thousands of an inch off and no more.
