SuperCooper wrote:
http://www.classicmotoring.net.au/cmos/faqs/mastercylinder.html
Australian Minis from around 1969 to 1976 were fitted with plastic tank master cylinders, made by either Lockheed or Girlock. Lockheed master cylinders have a cast iron body and the Girlock master cylinders have an alloy body, but are otherwise the same. In contrast to the tin tank master cylinders, plastic tank master cylinders are 0.75" bore diameter for the brake, and 0.7" for the clutch.
This style of master cylinder is no longer available new.
That information is wrong. The bore sizes are arse about.
For evidence, ALL Cooper 1275S had a .70" bore brake MC.
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
