Water pump update https://www.ausmini.com/forums/viewtopic.php?f=2&t=88881 |
Author: | bluewhitecoopers1968 [ Sun Mar 15, 2015 12:56 pm ] |
Post subject: | Water pump update |
Hi all, some who know me better might have heard me always going on about my engine always running hot. I finally bought a deep impeller pump. Hopefully this will fix the problem, along with a new alloy radiator. ![]() ![]() |
Author: | Phil 850 [ Sun Mar 15, 2015 3:01 pm ] |
Post subject: | Re: Water pump update |
What alloy radiator are you buying ? |
Author: | bluewhitecoopers1968 [ Sun Mar 15, 2015 3:05 pm ] |
Winner Racing 50mm on eBay, already got it. Quite impressed with the quality for the cost. It's even been polished on the tanks. |
Author: | bluewhitecoopers1968 [ Sun Mar 15, 2015 3:10 pm ] |
Here's a pic of mine... ![]() |
Author: | Phil 850 [ Sun Mar 15, 2015 3:29 pm ] |
How much was it if you don't mind me asking. I might need a new one myself soon ! |
Author: | bluewhitecoopers1968 [ Sun Mar 15, 2015 3:38 pm ] |
Phil 850 wrote: How much was it if you don't mind me asking. I might need a new one myself soon ! About $150 delivered Do a search on eBay "winner racing mini" |
Author: | Rookiepilot [ Mon Mar 16, 2015 9:32 am ] |
There was an article written by Keith Calver suggestion you need to check the running clearance on those deep impellor pumps, as sometimes the clearance between the impellor and pump body can be too great resulting in less efficiency than the tin impellors. Can't remember what the clearance should be. |
Author: | bluewhitecoopers1968 [ Mon Mar 16, 2015 12:36 pm ] |
Rookiepilot wrote: There was an article written by Keith Calver suggestion you need to check the running clearance on those deep impellor pumps, as sometimes the clearance between the impellor and pump body can be too great resulting in less efficiency than the tin impellors. Can't remember what the clearance should be. I'll have to check that out, seems about 1.5 mm. |
Author: | drmini in aust [ Mon Mar 16, 2015 12:50 pm ] |
From memory should be 1mm. |
Author: | bluewhitecoopers1968 [ Mon Mar 16, 2015 4:21 pm ] |
drmini in aust wrote: From memory should be 1mm. Just got home and checked it, 1mm or a little less mabe. Happy day's ![]() |
Author: | bluewhitecoopers1968 [ Sat Apr 04, 2015 1:59 pm ] |
Update.... The pump and radiator are installed. Radiator just fits, I had to modify the lower bracket and upper mount, also adjust the holes in the cowel. Attachment: 20150404_145220.jpg
Author: | JR0000 [ Sat Apr 04, 2015 2:21 pm ] |
Looks good ! |
