It is currently Fri Jul 18, 2025 9:04 pm
 Post subject: Cobra seats low back
PostPosted: Sun Mar 22, 2015 4:13 pm
Hi,
Just wondering if back seat access is restricted when fitting cobra seats and new runners to a clubman. The clubman seats move forward and tilt forward so just wondering how the cobra runners work?
Also what is the best method for repairing floor holes when removing a roll bar?
Thanks
 Post subject: Re: Cobra seats low back
PostPosted: Sun Mar 22, 2015 4:50 pm
I have low back Cobras in my GT
They do slide forward and lift up from the rear. But is a little harder to get in and out of due to the shape of the seat.
PostPosted: Sun Mar 22, 2015 4:58 pm
"Also what is the best method for repairing floor holes when removing a roll bar?"
Papier-mâché like all good panel shops use :D
If it's only bolt holes I would use a blob of Sika and paint over it.
PostPosted: Sun Mar 22, 2015 8:23 pm
Why not just put some shorter S/Steel cup head type bolts with rubber washers on them in the holes?
PostPosted: Sun Mar 22, 2015 10:32 pm
You could just use rubber bungs.....
Or pull the welder out and weld them up (if you have one)
PostPosted: Mon Mar 23, 2015 8:40 am
Appreciate the responses thanks
