hydro vs dry front subframe https://www.ausmini.com/forums/viewtopic.php?f=2&t=88953 |
Author: | boomini [ Mon Mar 23, 2015 10:01 pm ] |
Post subject: | hydro vs dry front subframe |
Hey guys just curious is a dry subframe the same as a hydro? My hydro frame has a few cracks in it and I beleive its bent. I got a blasted and painted dry frame here just wondering if the hydro will fit in it? |
Author: | MiniVLT [ Tue Mar 24, 2015 3:18 am ] |
Post subject: | Re: hydro vs dry front subframe |
The top of the front towers where the hydro sits up against is slightly higher than a dry one where the cone sits up against. I know you can put dry into a wet frame with hilo's, but don't know if you can go wet into a dry frame! Cheers Shane |
Author: | drmini in aust [ Tue Mar 24, 2015 7:42 am ] |
Hydro frame has a bayonet bracket inside, to hold the bag. Dry frame does not. So yeah you can put a rubber cone into a wet frame after you bash the bayonets in, but not the opposite. |
Author: | boomini [ Tue Mar 24, 2015 7:43 pm ] |
Bugger |
Author: | haze blue 850 [ Tue Mar 24, 2015 8:43 pm ] |
Greetings All. Sorry to cut in, but I've been curious about front frames. Are all dry front frames the same? Will a roundy fit a Leyland '78? Thanks Alex. |
Author: | drmini in aust [ Tue Mar 24, 2015 9:26 pm ] |
haze blue 850 wrote: Greetings All. Sorry to cut in, but I've been curious about front frames. Are all dry front frames the same? Will a roundy fit a Leyland '78? Thanks Alex. Yes the Oz ones are all the same mountings, wet or dry. We never got the Pommy rubber mounted single bolt ones. Years ago I put a 998 minimatic lump with hydro into a `76 Clubby, bolted straight in. Be aware the dry frames have an oval spacer on top of the towers, hydro frames don't. |
Author: | haze blue 850 [ Wed Mar 25, 2015 6:51 pm ] |
Thanks Doc. Just got home. Alex. |
Author: | 69k1100 [ Wed Mar 25, 2015 8:39 pm ] |
You could carefully remove the wet bayonet fixings from your bent subframe and transfer them to a dry frame. Just a thought, they were only spot welded. |
Author: | willy [ Wed Mar 25, 2015 9:05 pm ] |
What do these bayonets look like? I'll be removing them when I do a dry conversion in the near future. |
Author: | Scoop [ Wed Mar 25, 2015 9:09 pm ] |
Mitch has front hydro frames in his gumtree add. Any of them any good? |
Author: | simon k [ Fri Mar 27, 2015 3:17 pm ] |
willy wrote: What do these bayonets look like? I'll be removing them when I do a dry conversion in the near future. just little tabs that lugs on the side of the bags lock in to - push bag up, rotate to lock I put rubber cones in a hydro car once by just grinding slots into the cones to fit over the tabs... worked fine |
Author: | TheMiniMan [ Fri Mar 27, 2015 3:52 pm ] |
we just bent the 4x tabs in each of the frame towers back out of the way, fit donuts, job done must use Hi-los tho or car will sit on the deck,,,fully sick bro ![]() |
Author: | willy [ Sat Mar 28, 2015 1:12 pm ] |
Cool, cheers gents! |
