Priming oil pump
https://www.ausmini.com/forums/viewtopic.php?f=2&t=88973
Author:  Fishyoil [ Thu Mar 26, 2015 12:25 pm ]
Post subject:  Priming oil pump
Hi all.
Is it possible to prime the oil pump by jacking up the front of the car and turning one of the wheels backwards whilst in 4th?
Garage is small so I can't really roll it back far...
Author:  drmini in aust [ Thu Mar 26, 2015 1:22 pm ]
Post subject:  Re: Priming oil pump
Yes, jack 1 side up and put the handbrake on. Works fine. Also good for adjusting the rockers, etc.
Author:  Fishyoil [ Thu Mar 26, 2015 1:39 pm ]
Thanks doc. Will give it a go.
So I shortly found out can't do it with both wheels of the ground. Something to do with the diff I take.
Author:  drmini in aust [ Thu Mar 26, 2015 1:43 pm ]
That is correct. It needs 1 wheel on the deck, unless you are running an LSD.
Author:  Fishyoil [ Thu Mar 26, 2015 3:18 pm ]
Done.
For future reference, all this priming stuff also helps diagnose if you have a stuck clutch plate (which I didn't but thought I had with 2 noob wheels of the ground). If the wheel freely turns backwards without resistance, it could be that the clutch plate is stuck due to long term storage.
