It is currently Tue Jul 22, 2025 1:58 pm
PostPosted: Mon Mar 23, 2015 10:01 pm
Hey guys just curious is a dry subframe the same as a hydro?
My hydro frame has a few cracks in it and I beleive its bent. I got a blasted and painted dry frame here just wondering if the hydro will fit in it?
Minis..
1976 van daily drive
1975 van
1968 deluxe in the shed
1967 deluxe high strung 1310
1959 austin healey sprite
PostPosted: Tue Mar 24, 2015 3:18 am
The top of the front towers where the hydro sits up against is slightly higher than a dry one where the cone sits up against.
I know you can put dry into a wet frame with hilo's, but don't know if you can go wet into a dry frame!
Cheers Shane
PostPosted: Tue Mar 24, 2015 7:42 am
Hydro frame has a bayonet bracket inside, to hold the bag. Dry frame does not.
So yeah you can put a rubber cone into a wet frame after you bash the bayonets in, but not the opposite.
PostPosted: Tue Mar 24, 2015 7:43 pm
Bugger
Minis..
1975 van
PostPosted: Tue Mar 24, 2015 8:43 pm
Greetings All.
Sorry to cut in, but I've been curious about front frames.
Are all dry front frames the same?
Will a roundy fit a Leyland '78?
Thanks
Alex.
PostPosted: Tue Mar 24, 2015 9:26 pm
haze blue 850 wrote:
Greetings All.
Thanks
Alex.
Yes the Oz ones are all the same mountings, wet or dry. We never got the Pommy rubber mounted single bolt ones.
Years ago I put a 998 minimatic lump with hydro into a `76 Clubby, bolted straight in.
Be aware the dry frames have an oval spacer on top of the towers, hydro frames don't.
PostPosted: Wed Mar 25, 2015 6:51 pm
Thanks Doc.
Just got home.
Alex.
PostPosted: Wed Mar 25, 2015 8:39 pm
You could carefully remove the wet bayonet fixings from your bent subframe and transfer them to a dry frame. Just a thought, they were only spot welded.
PostPosted: Wed Mar 25, 2015 9:05 pm
What do these bayonets look like? I'll be removing them when I do a dry conversion in the near future.
PostPosted: Wed Mar 25, 2015 9:09 pm
Mitch has front hydro frames in his gumtree add. Any of them any good?
1963 Morris 850 Smoke Grey
1963 Morris 850 Shadow Blue
1965 Morris Mini Smooth Van
1966 Morris Mini Van
1969 Morris Mini Deluxe Resto
5/72 Clubman Gt
PostPosted: Fri Mar 27, 2015 3:17 pm
just little tabs that lugs on the side of the bags lock in to - push bag up, rotate to lock
I put rubber cones in a hydro car once by just grinding slots into the cones to fit over the tabs... worked fine
PostPosted: Fri Mar 27, 2015 3:52 pm
we just bent the 4x tabs in each of the frame towers back out of the way, fit donuts, job done
must use Hi-los tho or car will sit on the deck,,,fully sick bro :-)
PostPosted: Sat Mar 28, 2015 1:12 pm
Cool, cheers gents!
