Stuck Door https://www.ausmini.com/forums/viewtopic.php?f=2&t=89077 |
Author: | kaka [ Mon Apr 06, 2015 2:01 pm ] |
Post subject: | Stuck Door |
My passenger door looks like it has dropped a bit and it won't release, it is stuck and will not open. Are there any tricks to opening the door? It is a clubman. |
Author: | drmini in aust [ Mon Apr 06, 2015 3:35 pm ] |
Post subject: | Re: Stuck Door |
Remove door + hinges from body? |
Author: | Morris 1100 [ Mon Apr 06, 2015 3:44 pm ] |
It is probably the rocker arm on the linkage that has moved, it mounts on the door handle nuts. Removing the hinges isn't going to remove a door with a burst proof lock. |
Author: | drmini in aust [ Mon Apr 06, 2015 4:11 pm ] |
Morris 1100 wrote: It is probably the rocker arm on the linkage that has moved, it mounts on the door handle nuts. Removing the hinges isn't going to remove a door with a burst proof lock. No but it will free up the linkage by removing the load, if any. [ps if you have a head-on like my son did, the hinges broke- it DID remove the door from the `burst proof lock!] ![]() |
