Fitting pins into roller bearing
https://www.ausmini.com/forums/viewtopic.php?f=2&t=89099
Author:  anza [ Wed Apr 08, 2015 11:25 am ]
Post subject:  Fitting pins into roller bearing
Hi all,
I have removed my rear radius arms to clean and check. While cleaning on one arm all the pins fell out of the needle roller bearing. I am having a lot of issues refitting them. The casing all seems OK. Is there a easy/trick to refit the pins back in? The last pin is very hard to insert. Thanks
Author:  Geordie [ Wed Apr 08, 2015 11:46 am ]
Post subject:  Re: Fitting pins into roller bearing
Pack the bearing shell with a little bit of bearing grease then fit the rollers into the race the grease will help keep everything in place
Author:  anza [ Wed Apr 08, 2015 11:56 am ]
Do you need to have all the pins on a angle so the last one goes in. I just can't get the last pin in...
Author:  simon k [ Wed Apr 08, 2015 12:37 pm ]
get a new bearing
Author:  Timbo [ Wed Apr 08, 2015 2:54 pm ]
Simon has the answer, the rollers aren't meant to be able to come out of the bearing - or go back in again - its stuffed.
Author:  drmini in aust [ Wed Apr 08, 2015 2:55 pm ]
I agree with above. New bearings are cheap.
[edit] the old rollers are bound to be worn out of round anyway. Check the shaft- if there are chatter marks from the rollers, bin it and buy a new kit.
Author:  Morbo28 [ Wed Apr 08, 2015 6:43 pm ]
Same - new bearing for sure.
Author:  anza [ Thu Apr 09, 2015 8:49 am ]
Thanks for all the feed back.
