It is currently Tue Jul 29, 2025 6:14 pm
PostPosted: Wed Apr 08, 2015 11:25 am
Hi all,
I have removed my rear radius arms to clean and check. While cleaning on one arm all the pins fell out of the needle roller bearing. I am having a lot of issues refitting them. The casing all seems OK. Is there a easy/trick to refit the pins back in? The last pin is very hard to insert. Thanks
PostPosted: Wed Apr 08, 2015 11:46 am
Pack the bearing shell with a little bit of bearing grease then fit the rollers into the race the grease will help keep everything in place
66 Van 1275
69 K Sedan
69 K Van Teabag
66 austin Countryman
68van
PostPosted: Wed Apr 08, 2015 11:56 am
Do you need to have all the pins on a angle so the last one goes in. I just can't get the last pin in...
PostPosted: Wed Apr 08, 2015 12:37 pm
get a new bearing
PostPosted: Wed Apr 08, 2015 2:54 pm
Simon has the answer, the rollers aren't meant to be able to come out of the bearing - or go back in again - its stuffed.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Wed Apr 08, 2015 2:55 pm
I agree with above. New bearings are cheap.
[edit] the old rollers are bound to be worn out of round anyway. Check the shaft- if there are chatter marks from the rollers, bin it and buy a new kit.
Last edited by drmini in aust on Wed Apr 08, 2015 8:19 pm, edited 1 time in total.
PostPosted: Wed Apr 08, 2015 6:43 pm
Same - new bearing for sure.
PostPosted: Thu Apr 09, 2015 8:49 am
Thanks for all the feed back.
