Engine number? https://www.ausmini.com/forums/viewtopic.php?f=2&t=89114 |
Author: | amshaw [ Fri Apr 10, 2015 4:20 pm ] |
Post subject: | Engine number? |
Hi there, Im wondering if anybody can help please? I cant seem to find the engine number of a car Im looking at tomrrow. Its; 99H702ViH2100. Im not sure if its an i or a 1. Owner tells me its a 1100cc, but I just want to make sure. Ive tried a few motor decoders without luck. Thanks guys. |
Author: | timmy201 [ Fri Apr 10, 2015 4:31 pm ] |
Post subject: | Re: Engine number? |
The 99 at the start would suggest it is a 998 block. It may well have been fitted with a 1098 crank and pistons at some stage however.. |
Author: | Morris 1100 [ Fri Apr 10, 2015 4:36 pm ] |
99 means 998. Unless it has had the crankshaft changed it is a 998. |
Author: | amshaw [ Fri Apr 10, 2015 5:53 pm ] |
Ok thanks guys. So im guessing if its a differant crank it would increase the stroke = more cc's? He also said has been bored 40thou with flat top pistons and lumpy cam. We will get more info in the morning. |
Author: | Morris 1100 [ Fri Apr 10, 2015 6:03 pm ] |
You can stick an 1100 crank in a 998. They are the same block. |
Author: | drmini in aust [ Fri Apr 10, 2015 7:09 pm ] |
Morris 1100 wrote: You can stick an 1100 crank in a 998. They are the same block. But you need 1100 pistons too, the pin height is 3.75mm different. But conrods are the same. |
Author: | amshaw [ Sat Apr 11, 2015 9:26 pm ] |
Thanks again. It indeed have a 1100 crank put in it..........eitherway we bought it and it sounded great! |
