Centre caps for Contessa"s https://www.ausmini.com/forums/viewtopic.php?f=2&t=89133 |
Author: | bluewhitecoopers1968 [ Sun Apr 12, 2015 11:54 am ] |
Post subject: | Centre caps for Contessa"s |
Hi all, does anyone know where I could get centre caps for Contessa"s? Something like pictured. ![]() ![]() |
Author: | timmy201 [ Sun Apr 12, 2015 2:30 pm ] |
Post subject: | Re: Centre caps for Contessa |
Mine have 62mm holes, so something like this might fit. (It's also the same size as the lids on aerosol cans) http://pages.ebay.com/link/?nav=item.vi ... 1669508070 The wheel repair shop near me had bunches of them to choose from |
Author: | Bill B [ Sun Apr 12, 2015 6:47 pm ] |
I had a metal spinner make a set of caps to the exact size. Then I had these chrome plated. It's a bit fussy, but the results were excellent. |
Author: | bluewhitecoopers1968 [ Sun Apr 12, 2015 7:20 pm ] |
Post subject: | Re: Centre caps for Contessa"s |
Bill B wrote: I had a metal spinner make a set of caps to the exact size. Then I had these chrome plated. It's a bit fussy, but the results were excellent. Might have too look into making some custom caps. |
Author: | Mkb1275 [ Sun Apr 12, 2015 9:03 pm ] |
Ab has a set |
Author: | simon k [ Mon Apr 13, 2015 12:34 pm ] |
styrofoam cups work ![]() |
Author: | bluewhitecoopers1968 [ Mon Apr 13, 2015 12:36 pm ] |
simon k wrote: styrofoam cups work ![]() Might whittle a set out of a tree trunk. ![]() |
Author: | timmy201 [ Mon Apr 13, 2015 1:05 pm ] |
Here are some more: http://www.minispares.com/product/Class ... ACAPS.aspx I might actually buy a set of these, just need to check a few measurements first http://www.ebay.com.au/itm/CENTRE-CAPS- ... 19fe308921 |
Author: | bluewhitecoopers1968 [ Mon Apr 13, 2015 1:21 pm ] |
timmy201 wrote: Here are some more: http://www.minispares.com/product/Class ... ACAPS.aspx I might actually buy a set of these, just need to check a few measurements first http://www.ebay.com.au/itm/CENTRE-CAPS- ... 19fe308921 Mine measure 63mm, those minispares ones might work. The other chrome ones might be too tall for a Mini, unless you cut them down. Thanks for all the replies!! |
Author: | drmini in aust [ Mon Apr 13, 2015 1:31 pm ] |
Here's some I prepared earlier for a mate's S- machined from black HDPE. I'm not doing any more, but feel free to pinch the design. ![]() ![]() ![]() |
Author: | timmy201 [ Wed Aug 19, 2015 6:48 pm ] |
I found some caps at the wreckers today. Bit of a gamble as I didn't have anything to measure them at the time, but worth a go at $10 for a set of 7.. ![]() They ended up fitting quite nicely, they stick out about the same amount as the wheel nuts. Just need to peel off the logos and give them a quick polish! ![]() |
Author: | shnitzee [ Wed Aug 19, 2015 11:01 pm ] |
I talked to John @ Minikingdom on Monday about sourcing some; he said he's in the process of looking at having some made up. Not sure of time span involved though. Those ford ones look the job; great find. Eiles |
Author: | Garagedefend [ Thu Aug 20, 2015 8:07 am ] |
I;ve got some tall black caps here |
Author: | 1071 S [ Thu Aug 20, 2015 8:58 am ] |
Don't forget to measure the hole first ... not all Contestas have the same size center holes.. Cheers, Ian |
Author: | Davo111 [ Thu Aug 20, 2015 12:21 pm ] |
a can of coke cut in half, fits just nice, and their easily replaced. Even VB fit to, much better to empty than Coke. |
