It is currently Tue Jul 22, 2025 10:59 am
 Post subject: Seat belt hook
PostPosted: Sun Apr 12, 2015 6:23 pm
I have a 64 850 with Britax seat belts in the front.
On the drivers pillar is a hook for storage of the seatbelt.
There is a piece of bent coathanger wire on the passengers as there is no hook otherwise.
Is there a commercial "hook" that I can buy. I'm not worried about originality too much but something period woud be nice.
Phil
 Post subject: Re: Seat belt hook
PostPosted: Sun Apr 12, 2015 6:53 pm
this is what mine had
http://www.minis.com.au/minis/catalog/p ... c15869fceb
PostPosted: Mon Apr 13, 2015 11:30 am
peterb wrote:
Yes those were standard fitment 1966? on, they were NLA for quite a while until someone got them remade.
PostPosted: Mon Apr 13, 2015 12:11 pm
Quite fragile however. You only once have to forget to unclip them as you grab the belt and they're gone. They might have been better in metal. Nevermind, they're available and not at a great cost either.
PostPosted: Mon Apr 13, 2015 1:53 pm
I have a box full of old BMC seat belt bits as Dad was a seat belt engineer at BMC. Let me have a look you might be lucky.
The later style hook probably only suits the later belts where the tongue has a square hole.
PostPosted: Mon Apr 13, 2015 2:32 pm
If you want that particular style and not concerned about originality, you would likely find something at the hardware store, these packs have something similar but metal.
http://www.bunnings.com.au/ramset-wallm ... k_p2261042
1965 Riley Elf
1974 Ex Army Moke
1997 Rover Cooper
2002 JCW Cooper
2003 JCW Cooper S
PostPosted: Tue Apr 14, 2015 6:04 am
Seek and ye shall find. :D
PM me.
PostPosted: Tue Apr 14, 2015 9:08 am
The Mini King
That Would Be Me Kevin, I must be getting older than I thought, I was sure I told you I was having these made
PostPosted: Tue Apr 14, 2015 9:33 am
Hmmm, they look like they'd be easy to replicate with pinkisil and moulding them.
PostPosted: Tue Apr 14, 2015 11:35 am
I also found these. Anyone know what they were used on? They are like a much larger version of the post 1966 Mini hook. Maybe for the buckle tongue with the rectangular hole. Maybe not used on anything as Dad use to bring home lots of samples. Lots of Ford stuff, BMC and Ford seemed to be using the same seatbelt supplier around this time.
PostPosted: Tue Apr 14, 2015 1:43 pm
Phill - any part number embossed on either of those hooks?
PostPosted: Tue Apr 14, 2015 5:25 pm
My S has a piece of plastic coated wire looped around the webbing with a hook. Seems to work ok.
PostPosted: Tue Apr 14, 2015 10:30 pm
No Doug, the small ones nothing. I'm guessing they are part of the early Britax kit?
The large ones... one has a 2 and the other a 4 but they look identical.
I think they are for this type of buckle.
Users browsing this forum: No registered users and 39 guests
