door misalignment https://www.ausmini.com/forums/viewtopic.php?f=2&t=89143 |
Author: | i got a mini [ Sun Apr 12, 2015 8:05 pm ] |
Post subject: | Re: door misalignment |
I have the same problem but I think mine is because I wind up doors on a 850 no idea ![]() |
Author: | Harley [ Sun Apr 12, 2015 8:37 pm ] |
Phil - your car is one of the best I've seen for door alignment. Just leave it knowing many are worse! ![]() |
Author: | Phil 850 [ Sun Apr 12, 2015 9:08 pm ] |
Thanks Harley I just looked at the Minispares site and they suggest this http://minispares.com/product/Classic/B ... 0to%20shop This should cure the problem I have along with new catches. Maybe ![]() |
Author: | motodevo [ Sun Apr 12, 2015 10:28 pm ] |
Could just remove the rubber seal on it now and see whether there is any difference, save you forking out on new swals that may not be actually needed |
Author: | Goldbrocade_62 [ Mon Apr 13, 2015 1:06 am ] |
Incorrect door seals sliding window seals are a smaller section Karcraft, minisport list them |
Author: | Phil 850 [ Tue Apr 14, 2015 7:39 pm ] |
I have an 850 seal from minisport UK http://www.minisport.com/24a1351-seal-d ... mk1-2.html but it is a hard as ![]() Are there different versions of this seal. Needs to be a super soft one. |
Author: | drmini in aust [ Tue Apr 14, 2015 8:14 pm ] |
I'd try the 850 seals from Karcraft or minikingdomonline. |
Author: | Phil 850 [ Tue Apr 14, 2015 9:10 pm ] |
I might take my sample along and see if theirs is significantly softer. The one I have from minisport UK is 24A1351. Minispares and minisport AU list the seal as XGA9934 ? |
Author: | drmini in aust [ Tue Apr 14, 2015 10:04 pm ] |
Kc lists it as XGA9934. |
