starter solenoid location https://www.ausmini.com/forums/viewtopic.php?f=2&t=89182 |
Author: | drmini in aust [ Fri Apr 17, 2015 12:52 pm ] |
Post subject: | Re: starter solinoid location |
It was never mounted there on Oz cars. That wiring doesn't look right. Early cars had it on the clutch housing, later ones had it on the steady bar bracket like you had before. Where did you buy the harness from? |
Author: | DavidE [ Fri Apr 17, 2015 1:17 pm ] |
[quote="nicholasatkins"]Hi, previously my solinoid was located up next to the engine steady, however i have put a new mk2 cooper wiring harness in my van and the wiring for the solinoid drops down between the alternator and starter. Just after some photos of where i mounts to thanks The normal mounting position for the solenoid is above the bendix gear end of the starter motor, on a bracket which is fixed to the flywheel housing at the point where there are two tapped holes. Cheers |
Author: | nicholasatkins [ Fri Apr 17, 2015 2:08 pm ] |
Got the harness from vinwire everything else is stop on. |
Author: | DavidE [ Fri Apr 17, 2015 4:21 pm ] |
nicholasatkins wrote: Got the harness from vinwire everything else is stop on. It looks to me like you have the harness too far around the front of the engine. Try pulling it back along the inside front guard. |
Author: | michaelb [ Fri Apr 17, 2015 5:06 pm ] |
Post subject: | Re: starter solenoid location |
Does this help? There is a triangular bracket which mounts to the clutch housing Quote:
Author: | michaelb [ Fri Apr 17, 2015 5:10 pm ] |
Or this version 1976 Clubman Quote:
Author: | michaelb [ Fri Apr 17, 2015 5:15 pm ] |
Or a 1973 Clubman Quote:
Author: | peterb [ Sat Apr 18, 2015 1:54 am ] |
Don't suppose it could be for the Rover style solinoid. Just a thought. |
